semprenissart
Post by semprenissart on Jul 24, 2022 16:13:29 GMT -7
Does anyone know where to find them? Can’t see them on the US website.
semprenissart
Post by semprenissart on Aug 22, 2022 11:01:22 GMT -7
After a little bit of digging, it seems like the grip warmers for the tracer 9GT should/could (?) work. Might try it but first I need to find the harness and connectors on the MT10. I'm guessing they should be already on the bike since the manual says grip warmer are an option and heat levels can be changed from the TFT display.
Anyone know where these connectors might be?
semprenissart
Post by semprenissart on Aug 22, 2022 11:46:43 GMT -7
I found the connectors (they're under the windscreen). I'll order the grip warmers from the tracer 9GT (hoping they'll work properly) and will keep everyone updated!
2022mt10
Post by 2022mt10 on Aug 28, 2022 18:07:22 GMT -7
Please keep us posted. I might go the same route. I found this on the MT-09 forum. The grips are different for the non- cruise control models and he had to make a modification to the grip.
semprenissart
Post by semprenissart on Aug 29, 2022 10:48:08 GMT -7
The tracer gt grip warmers are backordered. Currently, it shows that I should get them at the end of September. I will try them as soon as I get them and will keep you all posted!
semprenissart
Post by semprenissart on Sept 8, 2022 15:27:24 GMT -7
So I finally got the grip warmers from the tracer9GT and unfortunately it's a no go. The issue is the throttle side is different on the MT10 (see pictures below)
I did connect them to the bike and they appeared in the menus as well as on the main screen. I was able to change the settings and they worked really well.
Unfortunately because the throttle tube is slightly different, the cover cannot be closed properly so i am returning them
semprenissart
Post by semprenissart on Sept 8, 2022 15:29:46 GMT -7
semprenissart
Post by semprenissart on Sept 8, 2022 15:48:42 GMT -7
Please keep us posted. I might go the same route. I found this on the MT-09 forum. The grips are different for the non- cruise control models and he had to make a modification to the grip. It seems like the tracer 9GT grip warmers are a perfect fit for the MT09 SP (CC version) Unfortunately I also found out that the MT09 SP stock throttle tube (BAM-26240-00-00) is different than the one from the MT10(BEA-26240-00-00) although the left grip (clutch side) is the same for both bikes (2C0-26241-00-00) which would expalin why the grip warmer from the tracer 9GT works with the MT09 SP but not the MT10
larsony99
Post by larsony99 on Oct 24, 2022 9:35:38 GMT -7
Please keep us posted. I might go the same route. I found this on the MT-09 forum. The grips are different for the non- cruise control models and he had to make a modification to the grip. Do you have a link to that thread? I have a set of grips for a 17 FZ-09 that I never got installed. I just picked up my 22 MT-10, but it sounds like based on this thread the throttle side won't work.
2022mt10
Post by 2022mt10 on Oct 24, 2022 10:07:17 GMT -7
Please keep us posted. I might go the same route. I found this on the MT-09 forum. The grips are different for the non- cruise control models and he had to make a modification to the grip. Do you have a link to that thread? I have a set of grips for a 17 FZ-09 that I never got installed. I just picked up my 22 MT-10, but it sounds like based on this thread the throttle side won't work. Realized that I didn't post the link. But I will try to find it.
2022mt10
Post by 2022mt10 on Oct 24, 2022 10:10:45 GMT -7
larsony99
Post by larsony99 on Oct 24, 2022 10:24:55 GMT -7
Excellent, thanks. I can check in the next few weeks if the 2017 FZ-09 grips can be retrofitted to the 22 MT-10. I'm not sure, but if so, that's excellent. I also don't see any grip heaters available right now in the US.
larsony99
Post by larsony99 on Oct 24, 2022 12:55:40 GMT -7
I am guessing not though, since the 2017 and 2021 MT-09s have different throttle tube part numbers.
larsony99
Post by larsony99 on Oct 24, 2022 15:23:10 GMT -7
I found the connectors (they're under the windscreen). I'll order the grip warmers from the tracer 9GT (hoping they'll work properly) and will keep everyone updated! Where under the screen? I took off the screen, the mount, and the plastic piece and all I got to was the turn signal wires and the back of the dash. Do I need to take off more?
larsony99
Post by larsony99 on Oct 24, 2022 15:26:38 GMT -7
Regarding the grips, mine don't have a throttle tube at all and are designed for any 7/8" bar. The battery in my calipers are dead, but they seem to be the same size visually. When I get some more time in a few weeks, I can take everything apart and see if the universal set and harness I got for the FZ-09 will work.
The part number of the grips I have is B67-H29A0-V0 and the bike harness I have is BS2-F62B0-V0.
semprenissart
Post by semprenissart on Oct 24, 2022 17:20:41 GMT -7
I found the connectors (they're under the windscreen). I'll order the grip warmers from the tracer 9GT (hoping they'll work properly) and will keep everyone updated! Where under the screen? I took off the screen, the mount, and the plastic piece and all I got to was the turn signal wires and the back of the dash. Do I need to take off more? these should be the heated grip wires not the turn signal wires unless we're not talking about the same thing? If you post a picture of it, I'll show you which connections exactly.
larsony99
Post by larsony99 on Oct 24, 2022 17:39:42 GMT -7
Where under the screen? I took off the screen, the mount, and the plastic piece and all I got to was the turn signal wires and the back of the dash. Do I need to take off more? these should be the heated grip wires not the turn signal wires unless we're not talking about the same thing? If you post a picture of it, I'll show you which connections exactly. These are what I'm talking about. I had assumed these were for the optional handguards with integrated blinkers that are available in Europe. One is black and one is grey. The only have 2/3 pins populated in each. ![](https://i.ibb.co/hFk24JV/18646-EAA-80-D0-460-A-9691-C78-AF3-D53701.jpg)
semprenissart
Post by semprenissart on Oct 24, 2022 17:46:54 GMT -7
Regarding the grips, mine don't have a throttle tube at all and are designed for any 7/8" bar. The battery in my calipers are dead, but they seem to be the same size visually. When I get some more time in a few weeks, I can take everything apart and see if the universal set and harness I got for the FZ-09 will work. The part number of the grips I have is B67-H29A0-V0 and the bike harness I have is BS2-F62B0-V0. I also had these on my MT09. They should work fine since it's the grip itself that is getting replaced, not the actual throttle tube. I doubt that you will be able to change the settings through the TFT screen though. I thought they were okay but not stellar. The one for the tracer gt seem much warmer with 10 different settings which is what I was hoping to have. When I plugged them on the 22 MT10, the TFT recognized it and I was able to go through all 10 settings and it felt VERY hot. The only issue was the throttle tube being different than the one on the MT10
semprenissart
Post by semprenissart on Oct 24, 2022 17:47:37 GMT -7
these should be the heated grip wires not the turn signal wires unless we're not talking about the same thing? If you post a picture of it, I'll show you which connections exactly. These are what I'm talking about. I had assumed these were for the optional handguards with integrated blinkers that are available in Europe. One is black and one is grey. The only have 2/3 pins populated in each. ![](https://i.ibb.co/hFk24JV/18646-EAA-80-D0-460-A-9691-C78-AF3-D53701.jpg) these are the grip warmer connections, or at least, they work as such as that's what I used to try the tracer 9GT grip warmers and they did connect fine and it showed up on the TFT
larsony99
Post by larsony99 on Oct 24, 2022 17:49:33 GMT -7
These are what I'm talking about. I had assumed these were for the optional handguards with integrated blinkers that are available in Europe. One is black and one is grey. The only have 2/3 pins populated in each. ![](https://i.ibb.co/hFk24JV/18646-EAA-80-D0-460-A-9691-C78-AF3-D53701.jpg) these are the grip warmer connections Got ya, okay. So the universal ones may or may not work if I can find a harness. Sounds like Yamaha pivoted and went with bike specific kits rather than universal with just a bike-specific harness. Worth the investigation at least.
