Post by clayton on Oct 30, 2018 19:58:54 GMT -7
Added some rim decals from eBay.
Post by clayton on Oct 30, 2018 19:59:21 GMT -7
narcissus
Post by narcissus on Oct 31, 2018 6:30:12 GMT -7
They look very similar to your first ones.
exuptoy
Post by exuptoy on Dec 31, 2018 4:38:35 GMT -7
Got my Christmas pressies fitted. Screen angel dash protection, Slip screen ice blue lamp protectors,
...and my recently purchased R&G crash protection. oh yeah, and my frame bungs (cheers ghostrider1127)
foggy
Post by foggy on Dec 31, 2018 20:51:13 GMT -7
@redgrcko59 That looks great, exactly what I’ve been trying to figure out how to do. Mind sharing where you found the coolant tank and how you mounted the signals ?
Post by Deleted on Jan 2, 2019 0:26:28 GMT -7
Hey, would you mind sharing where you bought those frame plugs? I'm interested on the subframe (upper) ones for sure, since I'm probably going to get the Abba stand that hooks up to the swingarm ends. But if not, then I'd get the right swingarm too (the left one looks better alone IMO). Many thanks.
ghostrider1127
Post by ghostrider1127 on Jan 2, 2019 2:26:58 GMT -7
exuptoy
Post by exuptoy on Jan 2, 2019 2:35:13 GMT -7
Hey, would you mind sharing where you bought those frame plugs? I'm interested on the subframe (upper) ones for sure, since I'm probably going to get the Abba stand that hooks up to the swingarm ends. But if not, then I'd get the right swingarm too (the left one looks better alone IMO). Many thanks. As per his post above, I was shown these by ghostrider1127 after he did his own bike. They sell a selection of five for £7.99 and the upper frame ones are 32mm and the lower pair are 45 & 51mm. www.motorcyclepartsstore.co.uk/fasteners-and-fixings/assortment-kits/locking-hole-plugs-black-nylon/
redgecko59
Post by redgecko59 on Jan 2, 2019 5:22:15 GMT -7
@redgrcko59 That looks great, exactly what I’ve been trying to figure out how to do. Mind sharing where you found the coolant tank and how you mounted the signals ? Tank came from Klein in Germany www.motorradklein.de/Here's another option I've seen, sure there's more.... shop.mgm-bikes.com/aid-3-Kuehlwasser-Ausgleichsbehaelter-schwarz-eloxiert.htmlAs for the signals, I traced the hole from the ears and cut them into the little panels leading to the headlights and fitted them there, even the wiring was long enough.
exuptoy
Post by exuptoy on Jan 2, 2019 17:13:36 GMT -7
That is neat!
foggy
Post by foggy on Jan 4, 2019 23:17:17 GMT -7
Thanks for the info.
Post by hooli on Jan 5, 2019 9:16:38 GMT -7
@redgrcko59 That looks great, exactly what I’ve been trying to figure out how to do. Mind sharing where you found the coolant tank and how you mounted the signals ? Tank came from Klein in Germany Now if only I could read German.
redgecko59
Post by redgecko59 on Jan 5, 2019 13:08:33 GMT -7
Tank came from Klein in Germany Now if only I could read German. Just hit "translate this page"...
Post by heathhudnall on Jan 5, 2019 14:23:34 GMT -7
Pro Bolt Ti axle nut arrived today. It's "blue", but it's more purple. Oh well, it's trick looking and light. I was going for trick looking...accomplished.
Post by evitzee on Jan 5, 2019 16:08:05 GMT -7
Only thing I did today is disconnect the Battery Tender, roll the bike out, top up the tire pressures, check oil level, and take a ride. Weather has been cold and rainy for many weeks and with holidays and vacations there was never a good day to rack up some miles. Today was about 70F, clear blue skies and no wind. Put 154 miles on a nice long loop with lunch thrown in. A well needed 'attitude adjustment' at this time of year. I good ride always clears my head and puts things in perspective. Went on reserve and had choice to take the boring road home (but with gas 6 miles away) or take the scenic route over the hills with gas 27 miles away. Took the long way and filled up with 4.246 gallons. Hardly any bugs this time of year so cleanup took just a couple of minutes. Weather is to turn bad on Monday so glad I got out today.
Post by Deleted on Jan 6, 2019 14:27:20 GMT -7
Pro Bolt Ti axle nut arrived today. It's "blue", but it's more purple. Oh well, it's trick looking and light. I was going for trick looking...accomplished. Looks great. Where did you buy it? I might go for a black one . But my question to you is if you used the factory recommended 137 ft/lbs of torque on it? Seems excessive to me, and it destroys even the factory nuts after a few uses. I used 120 after adjusting the chain, but it's still a ton. Wonder if that Ti one can take it, especially the finish. Remember my ex-Hayabusa called for 80 or so, if memory serves me right. Thx.
Post by heathhudnall on Jan 6, 2019 14:32:48 GMT -7
Pro Bolt Ti axle nut arrived today. It's "blue", but it's more purple. Oh well, it's trick looking and light. I was going for trick looking...accomplished. Looks great. Where did you buy it? I might go for a black one . But my question to you is if you used the factory recommended 137 ft/lbs of torque on it? Seems excessive to me, and it destroys even the factory nuts after a few uses. I used 120 after adjusting the chain, but it's still a ton. Wonder if that Ti one can take it, especially the finish. Remember my ex-Hayabusa called for 80 or so, if memory serves me right. Thx. Thank, got it directly from Pro Bolt in Great Britain. They day their Titanium nuts are stronger than grade 8.8 steel. I only tkrquedit 100 ft-lb. It was around $30.
