morbo
Post by morbo on May 10, 2018 7:09:29 GMT -7
Technically last night, it was late and I was tired... Installed a USB charger in place of the power outlet.
Post by heathhudnall on May 10, 2018 7:23:03 GMT -7
Technically last night, it was late and I was tired... Installed a USB charger in place of the power outlet. Got a link to where you got that?
morbo
Post by morbo on May 10, 2018 9:20:40 GMT -7
revolvingrain
Post by revolvingrain on May 12, 2018 14:38:01 GMT -7
Going to be straight piping my bike but instead of mounting it to where it originally was I'm going to mount the stock can right where the CAT originally was and the make some sort of housing for it. I'll let you guys know how that goes!
Post by heathhudnall on May 12, 2018 14:52:17 GMT -7
owle
Post by owle on May 12, 2018 22:53:25 GMT -7
Going to be straight piping my bike but instead of mounting it to where it originally was I'm going to mount the stock can right where the CAT originally was and the make some sort of housing for it. I'll let you guys know how that goes! That sounds interesting, surprised why a manufacturer has not come up with a design like the FJ-09 Akrapovic exhaust for the MT 10, there might be reasons that a long link pipe is used, there is enough room down there.
revolvingrain
Post by revolvingrain on May 13, 2018 11:46:15 GMT -7
Going to be straight piping my bike but instead of mounting it to where it originally was I'm going to mount the stock can right where the CAT originally was and the make some sort of housing for it. I'll let you guys know how that goes! That sounds interesting, surprised why a manufacturer has not come up with a design like the FJ-09 Akrapovic exhaust for the MT 10, there might be reasons that a long link pipe is used, there is enough room down there. Right? I have an image in my head that I think would look badass. I've been taking measurements and I'm going to have to cut the muffler down a bit to make it work. I talked to 2wheeldyno when I sent my ECU to get reflashed and they said okay that there wouldn't be a problem with the tune with the exhaust that short.
Post by Deleted on May 14, 2018 17:47:38 GMT -7
Rearsets are now black. I don't like positions of the aftermarket rears, so just painted the stock ones.
Post by papawheelie on May 14, 2018 17:53:14 GMT -7
Rearsets are now black. I don't like positions of the aftermarket rears, so just painted the stock ones. That looks great. And, I love that exhaust. If I had the money (and chose to delete the cat), that’s the one and only exhaust that I would go with.
xxscaxx
Post by xxscaxx on May 15, 2018 7:02:28 GMT -7
looks good ikem. I did this exact same thing but I sent my stuff out to get powdercoated so it would hold up better.
Post by Deleted on May 15, 2018 7:28:54 GMT -7
looks good ikem. I did this exact same thing but I sent my stuff out to get powdercoated so it would hold up better. they are actually originally painted. I have a local powdercoater, but I had the paint and time, so no cost to me so far. If it doesn't hold up, i will just get them coated.
xxscaxx
Post by xxscaxx on May 15, 2018 8:56:14 GMT -7
i'm stupid and didn't realize that you didn't get the foot peg painted, which is where I meant it holding up would be an issue. So since you don't have that, i'm sure its going to be fine lol
miglo
Post by miglo on May 15, 2018 16:22:43 GMT -7
madmagpul
Post by madmagpul on May 16, 2018 8:59:46 GMT -7
Do you have any pictures of them installed and off just so i can see how clean they look installed? I am highly considering some now and appreciate that you shared it!
revolvingrain
Post by revolvingrain on May 18, 2018 10:32:21 GMT -7
Did you have to install any relays to get that to work?
miglo
Post by miglo on May 18, 2018 13:26:37 GMT -7
Did you have to install any relays to get that to work? No, no relay needed, there was already 3-wires going to the stock signals. I just tied the Front and Side LED’s together on each side and ran them to the stock signals... I can make a wire diagram if you decide you want to do this...
revolvingrain
Post by revolvingrain on May 18, 2018 19:36:46 GMT -7
Did you have to install any relays to get that to work? No, no relay needed, there was already 3-wires going to the stock signals. I just tied the Front and Side LED’s together on each side and ran them to the stock signals... I can make a wire diagram if you decide you want to do this... I would appreciate it if you could! I'mm not great when it comes to wiring.
xxscaxx
Post by xxscaxx on May 21, 2018 8:17:10 GMT -7
xxscaxx
Post by xxscaxx on May 24, 2018 7:08:43 GMT -7
Top Block Racing belly pan came in yesterday. Took a quick pic.
