morbo
Post by morbo on Mar 30, 2018 13:20:39 GMT -7
Took some inspiration from Richie's bikes and swapped the cigarette lighter for 2 usb ports and a voltmeter. Luckily I'm no longer a smoker. I've been wanting to do this too since I saw his video. Only thing keeping me from installing one is you'll never know when you need to run something like a portable air compressor.
dewaynehasty
Post by dewaynehasty on Mar 30, 2018 13:49:02 GMT -7
Didn't he end up reverting back to a standard power outlet for that flexibility?
Post by achrista on Mar 30, 2018 15:24:43 GMT -7
I used to run an sae to usb adapter and connect it to the sae lead that came with my battery tender, and i used that all the time (particularly on longer trips for my phone and sena). I dont foresee going back to the cigarette lighter unless i run into qc issues with the Chinese usb sockets because I'd just use a cigarette => usb adapter anyway, and that's just 1 more thing to carry/forget. I cant think of any scenario where I'm carrying anything that would require a cigarette lighter -- never traveled with an air comp and odds are i never will.
justinnck1
Post by justinnck1 on Apr 14, 2018 14:26:48 GMT -7
I had Friday off work, so I got some local riding friends who were also off work and made a nice day ride on the MT. 300 miles of South East Ohio roads. I am still getting used to the bar end mirrors, but I can see well out of them.
hunkyleepickle
Post by hunkyleepickle on Apr 15, 2018 7:19:16 GMT -7
I managed to find a very shallow dual usb cigarette plug jobby off amazon that sinks far enough into the port that i can have usb and still put the weatherproof cover on it when not in use, while still being able to take it out for a compressor or other such stuff. As as aside, its really nice having a cheap, standard cigarette lighter type plug, after years of euro bikes with the more expensive power adapter in the dash! The cigarette ones are literally available at every roadside gas station in case i need another!
morbo
Post by morbo on Apr 16, 2018 13:17:35 GMT -7
I managed to find a very shallow dual usb cigarette plug jobby off amazon that sinks far enough into the port that i can have usb and still put the weatherproof cover on it when not in use, while still being able to take it out for a compressor or other such stuff. As as aside, its really nice having a cheap, standard cigarette lighter type plug, after years of euro bikes with the more expensive power adapter in the dash! The cigarette ones are literally available at every roadside gas station in case i need another! Mind sharing which one? I have a couple of spare ones but they're your typical bulkier type of plug. If I could keep one plugged in all the time that would be ideal, saves me from having to carry one on me.
paulb63
Post by paulb63 on Apr 16, 2018 21:17:43 GMT -7
I don't think you can run a compressor of it. It's only rated to 1 amp. (according to the manual) better to go straight to the battery.
morbo
Post by morbo on Apr 17, 2018 9:12:07 GMT -7
I don't think you can run a compressor of it. It's only rated to 1 amp. (according to the manual) better to go straight to the battery. Hadn't thought of that. Thanks for making that point. That puts a bit of a dent in my whole point for not swapping to a dedicated USB charger adapter as originally mentioned. I can't think of many things you'd need the OEM 12V DC power outlet versus the USB outlet, maybe older GPS devices. If hunkyleepickle replies back with which adapter he purchased I'd just go that route since I don't have to make any permanent modifications and still get a USB adapter which is sealed under the cover.
djstraub
Post by djstraub on Apr 25, 2018 6:08:13 GMT -7
Not today, but did this awhile ago... Morimoto switchbacks and pindicators 👍🏼 Those look awesome, have you got a link to which ones you bought ?
hunkyleepickle
Post by hunkyleepickle on Apr 25, 2018 20:20:51 GMT -7
I managed to find a very shallow dual usb cigarette plug jobby off amazon that sinks far enough into the port that i can have usb and still put the weatherproof cover on it when not in use, while still being able to take it out for a compressor or other such stuff. As as aside, its really nice having a cheap, standard cigarette lighter type plug, after years of euro bikes with the more expensive power adapter in the dash! The cigarette ones are literally available at every roadside gas station in case i need another! Mind sharing which one? I have a couple of spare ones but they're your typical bulkier type of plug. If I could keep one plugged in all the time that would be ideal, saves me from having to carry one on me. Yup, here's a link, it was from Amazon.ca, so can't be sure its the same product in other countries, but it seems to work just fine! www.amazon.ca/gp/product/B078WY7B6F/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
guywithfz10
Post by guywithfz10 on Apr 25, 2018 22:29:35 GMT -7
Installed the Woodcraft Clip-on conversion kit today. I installed it in the "Down" position. I know a few people here installed it in the "Up" position. A whole lot more aggressive and paired with my Woodcraft rearsets, it puts you in an awesome riding position for cornering and you feel a lot less wind especially at the helmet. Install is a little bothersome in the "Down" position, especially the brake line. The brake reservoir comes in contact with the front cowling piece covering the gauge cluster so you lose the steering lock and some range of motion for low speed steering.
morbo
Post by morbo on Apr 26, 2018 8:32:43 GMT -7
Mind sharing which one? I have a couple of spare ones but they're your typical bulkier type of plug. If I could keep one plugged in all the time that would be ideal, saves me from having to carry one on me. Yup, here's a link, it was from Amazon.ca, so can't be sure its the same product in other countries, but it seems to work just fine! www.amazon.ca/gp/product/B078WY7B6F/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1Thanks, I found one last week and saved it - AUKEY charger. After comparing it to the one you linked to, they look identical. Yours isn't available through Amazon.com.
thewnamanrules
Post by thewnamanrules on Apr 30, 2018 11:05:53 GMT -7
Over the Weekend - Visited Motorsport Exotica in ca... they are awesome bunch of folks... Had the Tuned... Results - started with 137HP ended with 148 HP -
Post by heathhudnall on May 2, 2018 15:37:43 GMT -7
I changed oil at the 600 mile mark today.
xxscaxx
Post by xxscaxx on May 3, 2018 7:06:06 GMT -7
I have so many things going on with this bike at the moment..can't wait to share some photos of it. But right now if you were to see what it looked like, you would think it was wrecked LOL
lund
Post by lund on May 4, 2018 16:54:23 GMT -7
Can we buy a TFT display that comes Standard on the sp model and put it on a 2018 Mt10?
guywithfz10
Post by guywithfz10 on May 4, 2018 18:41:30 GMT -7
Can we buy a TFT display that comes Standard on the sp model and put it on a 2018 Mt10? I want to say no because the TFT display has menu options and stuff that is hooked up to the electronic suspension that comes with the sp model. Just like how if you wanted to put the factory autoblipper the 2018 R1 has on 2015-2017 R1, you can't just put the autoblipper on. You need the blipper, new dash and new ECU. I think the TFT will only work if you were to get a new ECU and the electronic suspension off the SP model to hook up.
Post by heathhudnall on May 5, 2018 19:34:19 GMT -7
uknixter
Post by uknixter on May 7, 2018 12:34:03 GMT -7
xxscaxx
Post by xxscaxx on May 8, 2018 7:16:41 GMT -7
I have to say, i'm not a fan of the look of the Corbin, but just looking at that thing makes me want to sit on it lol. Bags look nice too. Been pondering about picking up something for mine but not sure.
I don't have photos but I just dropped off a slew of parts to the powdercoater yesterday. Getting the bars & risers, triple, the Brembo bracket for the R1 MC conversion, stock rearsets, shifter, and kickstand all done in matte black.
