Post by evitzee on Dec 19, 2017 15:53:28 GMT -7
Yamaha might be recommending something like the ABBA stand which lifts from the swingarm pivot point. They could also be recommending a phantom 'air hook'. A swingarm pivot point stand probably has 1% of the market, this is not what Yamaha means when they reference a maintenance stand. Look at their accessory page for what they are selling for the FZ-10......conventional bobbin swingarm spools, MotoGP style rear stand hooks, and a Harris Rear Hook-type stand. We are overthinking what a maintenance stand is......it is a stand that lifts the rear wheel using the swingarm, either by spools or hooks. Same outcome.
Kameo
Post by Kameo on Dec 19, 2017 18:40:54 GMT -7
If this happened on your previous bike and both were serviced by the same dealer, I'd check the alignment. We've seen this happen from time to time, but it's a rarity on modern o-ring chains... Different Yamaha dealerships.... Anyways cams been changed as has the chain...what’s the next port of call?
Post by stoltecmoto on Dec 21, 2017 5:46:50 GMT -7
From the Yamaha Service Manual, p. 3-19: Drive chain slack (Maintenance stand): 25-35 mm Drive chain slack (Side stand): 20-30 mm This would indicate that there is more slack using a paddock stand than the sidestand. Notice how both of those ranges cover the 25-30 mm range. Then note that that range is precisely what I recommended in my earlier post. It's important to remember that engineers do not write service manuals, and in fact, rarely even proof read them. We have mark ups with incorrect data in each and every service manual we have on the shelves. This covers Yamaha, Honda, Buell, Triumph, and KTM. They all have issues. But back on topic, within this bike's rear wheel's range of travel, there will be more chain slack when the rear wheel is hanging (unsupported, as if there were a center stand). As the suspension compresses and the axle moves into alignment with the countershaft AND swingarm pivot, the chain slack will decrease. Keep compressing past that point and the chain slack will increase again. The rear suspension is loaded more on a rear stand than a side stand, therefore the axle is closer to the tightest chain condition. Now anyway, the numbers I provided were determined NOT by the manual, but rather by experimentation. We remove the spring on the shock and run the rear suspension through it's full range of motion. This is the only way to collect data on the rear suspension's lever ratio. While we do this, we also check for proper chain tension. At it's tightest condition, we add enough slack and then record what that correlates to on the paddock stand. Back to the 25-30 mm number...which again, is what Yamaha recommends.
Post by stoltecmoto on Dec 21, 2017 5:47:29 GMT -7
If this happened on your previous bike and both were serviced by the same dealer, I'd check the alignment. We've seen this happen from time to time, but it's a rarity on modern o-ring chains... Different Yamaha dealerships.... Anyways cams been changed as has the chain...what’s the next port of call? Is the noise still present?
jjsc6
Post by jjsc6 on Dec 21, 2017 8:19:48 GMT -7
A paddock stand is not the same as a center stand. A paddock stand still loads the rear suspension. I must admit that I realized I had a brain fart after I saw your response. You are right. But even on a stand that supports the swingarm I'm quite sure that both of my bikes have significantly more slack on the "paddock" stand. I'm traveling and don't have time to check my theory though. But I do want to apologize in that my response was lacking the logic that I used. My bad. Old age setting in. That's my story and I'm sticking to it!
Post by papawheelie on Dec 21, 2017 9:42:20 GMT -7
From the Yamaha Service Manual, p. 3-19: Drive chain slack (Maintenance stand): 25-35 mm Drive chain slack (Side stand): 20-30 mm This would indicate that there is more slack using a paddock stand than the sidestand. Notice how both of those ranges cover the 25-30 mm range. Then note that that range is precisely what I recommended in my earlier post. It's important to remember that engineers do not write service manuals, and in fact, rarely even proof read them. We have mark ups with incorrect data in each and every service manual we have on the shelves. This covers Yamaha, Honda, Buell, Triumph, and KTM. They all have issues. But back on topic, within this bike's rear wheel's range of travel, there will be more chain slack when the rear wheel is hanging (unsupported, as if there were a center stand). As the suspension compresses and the axle moves into alignment with the countershaft AND swingarm pivot, the chain slack will decrease. Keep compressing past that point and the chain slack will increase again. The rear suspension is loaded more on a rear stand than a side stand, therefore the axle is closer to the tightest chain condition. Now anyway, the numbers I provided were determined NOT by the manual, but rather by experimentation. We remove the spring on the shock and run the rear suspension through it's full range of motion. This is the only way to collect data on the rear suspension's lever ratio. While we do this, we also check for proper chain tension. At it's tightest condition, we add enough slack and then record what that correlates to on the paddock stand. Back to the 25-30 mm number...which again, is what Yamaha recommends. Thank you stoltec. Thank you for taking the time to figure this out, and then share your findings. Valuable knowledge.
Post by stoltecmoto on Dec 22, 2017 6:31:00 GMT -7
A paddock stand is not the same as a center stand. A paddock stand still loads the rear suspension. I must admit that I realized I had a brain fart after I saw your response. You are right. But even on a stand that supports the swingarm I'm quite sure that both of my bikes have significantly more slack on the "paddock" stand. I'm traveling and don't have time to check my theory though. But I do want to apologize in that my response was lacking the logic that I used. My bad. Old age setting in. That's my story and I'm sticking to it! It's all good! It really comes down to suspension geometry. In this case, primarily the swing arm angle. A lot of cruisers have a 'negative' swing arm angle for that "really cool (but useless) slammed look". In other words, the axle is located HIGHER than the swing arm pivot! Any properly designed bike will have a positive swing arm angle to provide some degree of anti-squat. Anti squat is critical in ensuring that the shock operates in the right part of its stroke under all conditions. The chain tension will pull the wheel down with a positive swing arm angle, and conversely, up with a negative angle. With reason, down = good and up = bad. I'm going to predicate my earlier responses on the fact that every bike is different. While what I said is true of the -10 (and most other bikes), there are other considerations. For example, if the swing arm were allowed to droop far enough, the chain would start to 'wrap' around the swing arm pivot, thus tightening. Same with up travel. HOWEVER, this is highly unlikely in any scenario because good design prevents such a condition. It's also an extreme. Dirt bikes have a tremendous amount of wheel travel (most are 2.25-2.75 times the -10), so the chain tension can start getting funky. Here's another good explanation with visuals (everything except the bit about the alignment marks...good enough for a dirt bike, but NOT a street/track bike!): www.motosport.com/blog/how-to-tighten-your-dirt-bike-chain
Kameo
Post by Kameo on Dec 23, 2017 2:01:33 GMT -7
Different Yamaha dealerships.... Anyways cams been changed as has the chain...what’s the next port of call? Is the noise still present? It is....
Post by stoltecmoto on Dec 23, 2017 8:18:29 GMT -7
Got a new video? I can't tell with the last one...
Kameo
Post by Kameo on Dec 23, 2017 12:33:12 GMT -7
Got a new video? I can't tell with the last one... No new video for now. Try using headphones. I've run two tanks this week on BP 98 fuel and since doing so...the issue seems a little better? I normally only use 95 and usually not from my local BP. It's too early to tell if the fuels mitigated the problem as I've seen it go away in the past only to resurface a few hundred km's later. If fuel (98) has the potential to dampen the sound on the bike, might it suggest a problem with spark plug(s)? I'm going to keep running the same fuel for a couple of weeks to see if it stays the same and then change back to the previous and see if it goes back to how it was....much louder before. On a side note..behavior; On cold start she makes an excessively loud ticking noise for approximately 10 minutes and then settles down(fuel types made no difference to this behavior). Has done so since new. The noise I get here is a variation on the noise I'm trying to resolve in my video. With regards to the first 10 minutes of riding...When I take off and head down the road(say first 100 metres) the bike sounds brilliant and then it kicks in tick, tick, tick, tick, tick, tick - almost like one of those pod racers in star wars the phantom menace. Also, for the first 5000km's from new she would tick mostly in the 3-4000rpm range (like many others have reported) but this no longer seems to occur. When she is grinding/clattering (as in the video) I can almost feel it in the bike as it reverberates in me and when it happens it leaves you feeling like she's having to work harder than she otherwise does when it's not present. Probably just because I'm actually feeling the vibes.
Post by papawheelie on Dec 23, 2017 19:44:49 GMT -7
So, I also feel that my FZ is noisy — both at the drive chain, and on the top end of the motor.
My drive chain seems to be perfectly adjusted, though. Slack is exactly what it should be, every way I measure it. Visual inspection says that the chain tracks perfectly centered on the rear sprocket. Finally, I took the time to check rear wheel alignment a couple weeks ago, using the "string method", and it is perfectly aligned. So, I am trying to be at peace with the idea that it’s just how it is. It is my first road bike with a chain. Prior bikes have had drive belts, which are remarkably quiet and easy to maintain.
My top end ticks and clicks exactly as yours does in your video, and I don’t like it. They could be twins. It seems/sounds wrong to me. I took it to the dealership recently to ask their tech to look/listen with me, feeling pretty certain that they would agree that it sounded wrong. I described the noise as a prominent ticking that happens pretty consistently, and is very easy to hear in gears 2, 3, and 4, at RPMs between 3k and 4K, when the motor is running fast enough to make the noise, but we’re not moving so fast that all sound is drowned out by wind noise and such.
Well, they listened to it and rode it and returned it to me saying that it is running exactly as it is supposed to. My FZ is tip-top, it turns out, and the acknowledged ticking and clicking is completely normal — it’s simply the sound that this motor makes. Then they charged me $125 for that "service", despite the fact that I’ve had the bike only two months, and put only 2,500 miles on it. On the invoice, they did add a list of things that they supposedly checked — I think to suggest that they at least lubed up a bit for me. Evidently, that’s just the "yamatick", as others have described it. The tech tried to describe it to me — why it does what it does. He even suggested that if I wanted a smooth, quiet, purring engine, I should have bought a Honda. Haha!! I still don’t like it, though.
Anyway, I’m going to install a manual cam chain tensioner, as so many others have done, and seem to be pleased.
If that that doesn’t work, I’m just gonna install a louder exhaust and ride the sh!t out of it.
So...what did the dealer tell you? If they replaced the auto cam chain tensioner, they evidently agreed that it didn’t sound right? What do they say now, that it still makes the same noise?
Kameo
Post by Kameo on Dec 24, 2017 14:34:18 GMT -7
The yamaha tick... M onster of T ick 10
Is not my issue I’m trying to resolve. The obvious tick in the 3-4,000 rpm range seems to have dissipated around the same time she started wihining and grinding. When I picked it up after having the drive chain and tensioner replaced they said it didn’t resolve the problem. Told me to give it 500 and bring her back for a chain tighten and then if its still happening i’l need to leave it with them for a week. They are stumped and will likely need to rely on the yammy reps for guidance. It was reaffirmed to me they are noisy bikes. What a crock, I've ridden others and they do not behave like mine. Something doesn't seem right.
Yamaha reps had to view, test and allow for parts to be replaced under warranty, so they obviously acknowledge there is a problem but to then say they are noisy after the attempted solution failed seems like a weak argument.
I’m thinking of taking it in, in the new year, to a local mechanic who is reputable and willing to isolate the issue for me, at a cost obviously. Will see how it goes in the comming weeks.
let me know how it goes with the manual tensioner....
Post by stoltecmoto on Dec 26, 2017 11:10:20 GMT -7
The comment on the fuel is an interesting one. Are you hearing detonation (knock)? If your standard brand and octane isn't working, you may need to find a better supplier. Not all fuel is considered equal (at least here in the states).
What kind of oil are you using in the engine? Another one of those 'not all oils are equals'...but for fear of turning this into an oil thread, I'll stop there.
Kameo
Post by Kameo on Dec 26, 2017 14:17:11 GMT -7
The comment on the fuel is an interesting one. Are you hearing detonation (knock)? If your standard brand and octane isn't working, you may need to find a better supplier. Not all fuel is considered equal (at least here in the states). What kind of oil are you using in the engine? Another one of those 'not all oils are equals'...but for fear of turning this into an oil thread, I'll stop there. @ 10,000km's/12 month service; "as part of the service and in an attempt to quiet the untidy noise the bikes been making while riding they changed the oil from 10w40 to 15w50." This is what they said Yamaha Australia's been recommending for the 10's and R1's. It didn't make any difference what soever. SO it now has 15w50.
Post by stoltecmoto on Dec 27, 2017 6:06:30 GMT -7
Yamalube 15w50 is pretty good for hot temps, so that's probably a solid change. It's a long shot, but I'd start playing with the fuels you're using to see if the brands and octane ratings have a repeatable effect.
Kameo
Post by Kameo on Dec 27, 2017 13:57:53 GMT -7
Yamalube 15w50 is pretty good for hot temps, so that's probably a solid change. It's a long shot, but I'd start playing with the fuels you're using to see if the brands and octane ratings have a repeatable effect. Hey stoltecmoto, the recommended fuel type is 95 on the 10. 98 costs a lot more and is considered overkill. I'm using 98 at the moment and finding it runs quieter/better for now. If others are riding fine with 95 what does it suggest on my bike if 98 mitigates the noises I'm hearing...? "Those numbers – 91, 95 and 98 – are the so-called ‘octane rating’ of the fuel. They’re all about the same in terms of the energy in the fuel. What octane really is, is an index of a fuel’s resistance to burning too early inside your engine – if that happens, it causes ‘pinking’ or ‘pinging’ (same thing), which is mechanically destructive at high revs and large throttle openings." Mine definitely occurs at higher revs...for sure. I really need to compare the sound created when an engine is pinking/pinging to compare it with what I hear....It's not the word/term I would have thought to use to explain my issue. Ps. If it turns out to be fuel related I might try dropping back to 95 from BP and stop using fuel from the regular place I would normally fill up from. Pss. I just watched this and whilst it's difficult to make out for sure it's looking like I might be getting spark knocking...
Post by stoltecmoto on Dec 27, 2017 14:33:37 GMT -7
Octane rating is one of the more straight forward parts of fuel ratings. But there's a whole lot else in the fuel that matters...the cleansers and additives. Here in the states, we have a wide variety of fuels. Our octane ratings are different an just about everyone else in the world, but we can find anything from 85 to 93 readily...with higher on the fringe. Same with ethanol content. But the bottom line is that some fuels just suck.
The good news, is that its easily to isolate if fuel is causing the performance issue. Keep good notes and vary the supply. Most motorcycles do not have knock sensors like our four-wheeled brethren do, so the ECU cannot automatically pull timing when knock starts to occur. Fuel quality matters!
Kameo
Post by Kameo on Dec 28, 2017 17:29:09 GMT -7
Octane rating is one of the more straight forward parts of fuel ratings. But there's a whole lot else in the fuel that matters...the cleansers and additives. Here in the states, we have a wide variety of fuels. Our octane ratings are different an just about everyone else in the world, but we can find anything from 85 to 93 readily...with higher on the fringe. Same with ethanol content. But the bottom line is that some fuels just suck. The good news, is that its easily to isolate if fuel is causing the performance issue. Keep good notes and vary the supply. Most motorcycles do not have knock sensors like our four-wheeled brethren do, so the ECU cannot automatically pull timing when knock starts to occur. Fuel quality matters! Whilst the fuel has improved the noise to some degree I can now confirm aftern 3 tanks of top premium bp that it is still occurring, just not as loud as before and a slightly different pitch. I'm thinking now, given the dealerships got NFI to try and get the spark plugs replaced, even if I gotta pay for this myself. Everything I'm reading on spark knock and hearing is Saying it's worth a shot. ps. I will continue until I find a solution and keep my bike or my warranty nears expiry and il get rid of it.
Kameo
Post by Kameo on Jan 1, 2018 19:52:51 GMT -7
Bikes gone in for a tighten as new chain was installed 600km’s ago.
Different dealership this time and it’s sitting at 2cm as opposed to 5cm by the dealership that’s replaced the cam tensioner and chain.
Bike sounds much better. Still got something not right but better than b4.
Checked new bikes on the floor and all sitting around 2cm of slack.
So much tighter than the other dealerships settings for my chain but spec is 2-3 and given the better ride it produces...obviously the spec exists for a reason.
Which is what I’ve been telling the other Yama dealers all along. Falls on deaf ears tho...
Kameo
Post by Kameo on Jan 7, 2018 17:04:07 GMT -7
Yamaha's response in assessing my bike after first changing the cam tensioner. This is where its at for now...
"Thank you for your email and your concerns regards engine operational noises. As previously advised, these engines are noisy. Furthermore, varying engine assembly tolerances can account for noise levels to differ between same model units. We contacted XXXXX, YYYYY and ZZZZZ regarding your concern. Both XXXXXXX and YYYYYYYY advise that the engine noises are normal and consistent with the model. XXXXXXX did attempt to improve the noise level (under Reps advice) by changing the tensioner. XXXXXXX also advised that the noises were normal and consistent with model.
As previously advised, “the sound track supplied, we are unable to identify any abnormal operational noise. Ticking we could hear is constant and normal”.
If you feel the noise level has changed, increase in some way, then please have a dealer reassess."
