Post by slv on Feb 7, 2017 12:02:38 GMT -7
So, after getting the midpipe installed with the stock silencer, I felt air coming from under the front of the silencer. I thought I had a leak, so I removed the can and re-adjusted the clamp and gasket. I still felt air, but then I noticed a small hole at the front lower area of the silencer. Is this normal? What does it do? Are they all like this? Is it drain hole for trapped water? image org
audiblepop94
Post by audiblepop94 on Feb 7, 2017 14:32:20 GMT -7
Yes it is for water drainage. Most stock cans have this
Post by tigershark on Feb 7, 2017 17:11:30 GMT -7
So, after getting the midpipe installed with the stock silencer, I felt air coming from under the front of the silencer. I thought I had a leak, so I removed the can and re-adjusted the clamp and gasket. I still felt air, but then I noticed a small hole at the front lower area of the silencer. Is this normal? What does it do? Are they all like this? Is it drain hole for trapped water? image orgYour first picture looks like there's a large fractured area above the drain hole right behind the clamp?
Post by slv on Feb 7, 2017 17:30:17 GMT -7
So, after getting the midpipe installed with the stock silencer, I felt air coming from under the front of the silencer. I thought I had a leak, so I removed the can and re-adjusted the clamp and gasket. I still felt air, but then I noticed a small hole at the front lower area of the silencer. Is this normal? What does it do? Are they all like this? Is it drain hole for trapped water? image orgYour first picture looks like there's a large fractured area above the drain hole right behind the clamp? That's the anti-rotation feature fore the clamp.
Post by tigershark on Feb 7, 2017 18:23:29 GMT -7
Your first picture looks like there's a large fractured area above the drain hole right behind the clamp? That's the anti-rotation feature fore the clamp. Got it. Hard to tell by the picture.
Post by 0002s on Feb 7, 2017 18:30:10 GMT -7
My stock silencer makes holes.
Post by slv on Feb 7, 2017 18:41:31 GMT -7
That's the anti-rotation feature fore the clamp. Got it. Hard to tell by the picture. How's this?
Post by slv on Feb 7, 2017 19:40:23 GMT -7
My stock silencer makes holes. Nice rig!
Post by tigershark on Feb 7, 2017 21:38:21 GMT -7
Got it. Hard to tell by the picture. How's this? Still looks like a fracture, but I believe you.
Post by Cruizin on Feb 7, 2017 21:43:04 GMT -7
My stock silencer makes holes. Nice, meat on the table! I'm about to get at least 5 pm's from shocked non usa members about this, lol.
Post by 0002s on Feb 7, 2017 22:11:10 GMT -7
My stock silencer makes holes. Nice, meat on the table! I'm about to get at least 5 pm's from shocked non usa members about this, lol. They'll get over it. 55lbs worth of venison.
Post by Cruizin on Feb 7, 2017 23:38:47 GMT -7
Nice, meat on the table! I'm about to get at least 5 pm's from shocked non usa members about this, lol. They'll get over it. 55lbs worth of venison. Let me know when you are ready to come up Elk hunting some October! I'll fill your deep freezer! Out of state tags aren't too bad up here.
Post by slv on Feb 8, 2017 4:53:42 GMT -7
My experience is that people won't be offended by the hunting, but might question the need for fire power. I recognize it as a really nice tool of the game.
Post by 0002s on Feb 8, 2017 6:33:18 GMT -7
My experience is that people won't be offended by the hunting, but might question the need for fire power. I recognize it as a really nice tool of the game. I'm always ready to hunt. 95 lbs Oryx x
Post by 0002s on Feb 8, 2017 6:35:01 GMT -7
They'll get over it. 55lbs worth of venison. Let me know when you are ready to come up Elk hunting some October! I'll fill your deep freezer! Out of state tags aren't too bad up here. Sounds great. Do you have a guide you use?
Post by slv on Feb 8, 2017 7:40:29 GMT -7
My experience is that people won't be offended by the hunting, but might question the need for fire power. I recognize it as a really nice tool of the game. I'm always ready to hunt. 95 lbs Oryx x Nice! That's an African beast. Is it not? I'm not a hunter because I suck at it and have no patience, but I have enjoyed many meals of African game at restaurants in Johannesburg SA.
What caliber is that man-cannon? I can't tell from the picture, but it appears to be more than the standard 30-06.
I once had a Winchester 44-40 lever action that was designed for knocking buffalo down, but the speed was old school slow. I suspect that thing in your picture carries much more muzzle velocity that my old boom stick.
PS. I want to know more about this hardware. Specs please.
ebay image host
Post by 0002s on Feb 8, 2017 8:22:49 GMT -7
Yes, African. But it's a Texotic. Texas is the only place you can hunt these in the world. They are endangered everywhere else. The species is basically breed and managed through hunting. It's saved the species. It's really amazing that I can really hunt all of Africa in TX. The rifle in that picture is a custom 1895 Chilean Oberndorf Mauser in 7mm Mauser (actually smaller than 30.06). The round is a hand loaded 120 gr Nosler BT. The jacket you see was all that was recovered. The bullet actually passed through the cow Oryx and killed her Oryx calf (collateral damage hidden behind her in the tall grass) with a head shot through the ears (a two'fer with one bullet). It's not the arrow but the Indian. Shot placement always trumps big bullet. The rifle was built by me as a subsonic hunting weapon. I use this exclusively for hogs, sheep and deer (or anything of that size) at a max distance of around 150 yds. It does the job and saves my hearing (what little is left). 8.2" 300 BLK w/ACC suppressor. Optics are 1x4 Trijicon w/Bobro QD mount. Barrel: Noveske Trigger: 3.5 lb Timmney Rail: Daniel Defense Hardware: Magpul Gas Block: Noveske Bolt Carrier: YM Match Rounds are hand loaded 300 BLK w/194gr Lehigh Defense subsonic expanding bullets running around 1080 fps out of the muzzle.
Post by Deleted on Feb 8, 2017 8:33:32 GMT -7
Hmmmmm.....may need to start a Firearms thread in The Bar section for people to share their toys. :-)
Post by 0002s on Feb 8, 2017 9:17:55 GMT -7
Hmmmmm.....may need to start a Firearms thread in The Bar section for people to share their toys. :-) If there is interest in such devilish and devious things........
Post by slv on Feb 8, 2017 17:02:36 GMT -7
Dog Wick is interested.
