paulo2t
Post by paulo2t on Dec 11, 2016 22:31:13 GMT -7
Installed a Yamaha Quick Shift last week. WOW What a difference. So much fun. The harder you pull the throttle the smoother is the gear change. Even around town it is fun to use. Install is not hard at all. I highly recommend. upload image freegif hostingpic hostimagehosting
Post by slv on Dec 15, 2016 6:16:37 GMT -7
I put one on my bike too. It really is a bargain for what it does to the ride. Just click it and keep accelerating.
It would be nice to have downshift capabilities, but that is aftermarket, cost $800 and requires a ECU flash. For the $200 spent on the Yamaha part, I'm very happy with it.
NOTE. If you are in a 1st gear power wheelie when you shift to second, hold on tight.
Post by arcaos84 on Dec 15, 2016 8:15:49 GMT -7
I'm really considering this for my first mod on the bike. Only thing is that I do like the ability to feel and control the bike. I have a concern I would be desensitized to my inputs to the bike. Do you feel like you have a minor loss of feeling of the bike and control of the engine and throttle?
paulo2t
Post by paulo2t on Dec 15, 2016 9:53:24 GMT -7
arcaos84, No there's no loss of feeling changing gears or otherwise. You can still use the clutch if want to. It is specially hand if you are hard accelerating. No need to let go of the handlebar to pull the clutch lever. I do not know if I'm going faster, but I can say it feels a lot faster than using the clutch. I'm thinking of an eco flash, need to ask Nels about the auto blip, if it will work with the quick shifter. I'll be adding a K&N air filter too. Love this bike. The R1 is bit serious.
Post by slv on Dec 15, 2016 11:33:32 GMT -7
arcaos84, No there's no loss of feeling changing gears or otherwise. You can still use the clutch if want to. It is specially hand if you are hard accelerating. No need to let go of the handlebar to pull the clutch lever. I do not know if I'm going faster, but I can say it feels a lot faster than using the clutch. I'm thinking of an eco flash, need to ask Nels about the auto blip, if it will work with the quick shifter. I'll be adding a K&N air filter too. Love this bike. The R1 is bit serious. I agree. I don't feel as if I lost any touch or control. It's just better. Not just for this bike, the concept is just better than the clutch-n-shift method. After an hour or so, it's second nature, but you still feel the throttle position, revs, and every other thing the bike tells you.
Post by 0002s on Dec 17, 2016 16:17:27 GMT -7
I just ordered the MT-10 version from Europe. It appears to be a straight install with no cutting.
Post by Deleted on Dec 17, 2016 16:44:56 GMT -7
I just ordered the MT-10 version from Europe. It appears to be a straight install with no cutting. Links? ;-)
Post by 0002s on Dec 17, 2016 16:55:52 GMT -7
I just ordered the MT-10 version from Europe. It appears to be a straight install with no cutting. Links? ;-) www.motorcyclespareparts.eu
Post by 0002s on Dec 17, 2016 16:58:43 GMT -7
Post by slv on Dec 17, 2016 17:24:35 GMT -7
Post by 0002s on Dec 17, 2016 17:54:54 GMT -7
I need to do some more research on what's needed. The suspension monitoring would not work. The SP version should be a one to one swap though.
warnock
Post by warnock on Dec 17, 2016 17:58:21 GMT -7
I am gonna go with the FTECU quick shifter I think it's like $100 cheaper but you need your ecu flashed to use it.
Timbo
Post by Timbo on Dec 17, 2016 18:20:50 GMT -7
Since my bike is flashed and Active tune from FTECU, I'm getting their QS/Auto blipper.
jakefromstatefarm
Post by jakefromstatefarm on Dec 19, 2016 18:53:09 GMT -7
I put one on my bike too. It really is a bargain for what it does to the ride. Just click it and keep accelerating. It would be nice to have downshift capabilities, but that is aftermarket, cost $800 and requires a ECU flash. For the $200 spent on the Yamaha part, I'm very happy with it. NOTE. If you are in a 1st gear power wheelie when you shift to second, hold on tight. Are you located in the US? Where did you order your QS from?
Post by slv on Dec 19, 2016 23:08:11 GMT -7
I put one on my bike too. It really is a bargain for what it does to the ride. Just click it and keep accelerating. It would be nice to have downshift capabilities, but that is aftermarket, cost $800 and requires a ECU flash. For the $200 spent on the Yamaha part, I'm very happy with it. NOTE. If you are in a 1st gear power wheelie when you shift to second, hold on tight. Are you located in the US? Where did you order your QS from? Yes. In Savannah. I ordered mine through the Yamaha dealer in Savannah. They show it on the US Yamaha site now www.shopyamaha.com/product/details/gytr-quick-shifter-kit?b=Street+Motorcycle&d=28|28&f=2017|307
landmark518
Post by landmark518 on Mar 17, 2017 8:59:26 GMT -7
Can anyone tell me if the GYTR® Quick Shifter Kit provides clutchless downshifts also? Really considering getting one. Thnx
Post by Deleted on Mar 17, 2017 10:14:41 GMT -7
Can anyone tell me if the GYTR® Quick Shifter Kit provides clutchless downshifts also? Really considering getting one. Thnx No it doesn't. You need a different setup and programming for Auto-Blip. Substantial increase in cost.
landmark518
Post by landmark518 on Mar 17, 2017 10:43:06 GMT -7
Can anyone tell me if the GYTR® Quick Shifter Kit provides clutchless downshifts also? Really considering getting one. Thnx No it doesn't. You need a different setup and programming for Auto-Blip. Substantial increase in cost. Thanks Bogie, that's what I thought. I think I will go with this kit anyway. Seems pretty good based on what people are saying.
Post by Deleted on Mar 17, 2017 12:24:57 GMT -7
I love mine!!! Makes an already fun bike even more fun.
racer172
Post by racer172 on Mar 23, 2017 9:03:41 GMT -7
yeah the day I bought my bike I walked over to the parts counter and ordered the QS & windscreen..I still have neither. Kinda irritated about that. Regarding the QS I've been racing with it on my zx10 for a few years and it comes standard on my H2...just to address some of the concerns above the mod is a 100% + with no drawbacks. I don't use it when riding easy, I use the clutch because if you are not on the throttle 100% it is likely the shift attempt will not change gears (a miss-shift) or worse you could hit a false neutral. 2 times you absolutely WILL want to use the QS: when your flat out in a speed run, just pin the throttle and bang the gears up (and yes this does make you/your bike faster), and the other time a skilled rider can utilize the QS is when you are still leaned over exiting a turn and you need to get into a higher gear but are not ready to straighten the bike up you can keep constant throttle and up-shift without upsetting the suspension, not the case if you have to chop throttle and pull in the clutch for a shift.
