Post by sdshawn on Apr 6, 2021 17:14:04 GMT -7
I dont have a manual did not come with one bought used , maybe should get one someday. I did not mess with the sensor did not even think of it maybe getting damaged I should double check that . Every thing seems good as far as mechanical I loctite the rear bolt and greased the front on rear caliper then torqued all bolts. Still working on the perfect chain tension though the spec seems to tight for my liking . I use a chain monkey and chain alignment tool to get it perfect but at spec it get almost like a whine noise when it at spec .78 to 1.18 I like it 1.25 1.50 .
terrys
Post by terrys on Apr 6, 2021 21:13:25 GMT -7
Post by sdshawn on Apr 6, 2021 22:54:07 GMT -7
Yes I know I've seen them I usually search my answers I'm looking for online its almost quicker plus you may get more ways ideas to do whatever task . Like I know online manual rear axle torque is 137lbs without rehashing this topic IMO that's to much so I do 110 everything else sofar to spec. Pretty sure wheel will not slide forward past the adjusters and my axle slider should help keep my axle nut from backing off or use some loctite along with 110 lbs I'm not to worried Bout it coming loose..
