nedfeliciano
Post by nedfeliciano on Jan 21, 2018 6:18:14 GMT -7
New battery...all fuses look ok... The dealer will pick it up this week, hopefully this will be covered under a warranty. By the way I called a local dealer...the guy asked me to take my bike to the NY dealer I got it from (I am in NJ) ... then I called Motorcycle Mall...they will pick up my bike free if change!
av8er
Post by av8er on Jan 21, 2018 7:56:17 GMT -7
New battery...all fuses look ok... The dealer will pick it up this week, hopefully this will be covered under a warranty. By the way I called a local dealer...the guy asked me to take my bike to the NY dealer I got it from (I am in NJ) ... then I called Motorcycle Mall...they will pick up my bike free if change! When you say won't start, are you saying starter will not turn over and crank or just won't fire and start while engine is cranking via starter motor? Got to ask, kill switch in run?
daveinwoodland
Post by daveinwoodland on Jan 21, 2018 10:19:15 GMT -7
Wonder if it has anything to do with the side stand switch. Also curious if it's a "will crank and not start" or won't crank at all situation.
nedfeliciano
Post by nedfeliciano on Jan 21, 2018 11:09:15 GMT -7
Wonder if it has anything to do with the side stand switch. Also curious if it's a "will crank and not start" or won't crank at all situation. It cranks but it does not start , the starter must be ok
daveinwoodland
Post by daveinwoodland on Jan 22, 2018 11:50:48 GMT -7
So that would rule out some things such as the side stand switch and some fuses. Should be a warranty covered issue for sure wouldn't worry about that. Let yus know what you end up finding out.
Post by Deleted on Jan 22, 2018 14:49:02 GMT -7
Have you lifted up the tank recently? If so it is possible the plug for the fuel pump that fits into the bottom of the tank wasn't connected. The bike will crank but won't start if the fuel pump isn't running. An easy way to check is to stick your ear against the fuel tank and turn the ignition key to on. You should hear the fuel pump make a whirring noise as it primes.
nedfeliciano
Post by nedfeliciano on Jan 22, 2018 19:15:18 GMT -7
So that would rule out some things such as the side stand switch and some fuses. Should be a warranty covered issue for sure wouldn't worry about that. Let yus know what you end up finding out. I will keep you posted, thanks for your comments
nedfeliciano
Post by nedfeliciano on Jan 22, 2018 19:17:58 GMT -7
Have you lifted up the tank recently? If so it is possible the plug for the fuel pump that fits into the bottom of the tank wasn't connected. The bike will crank but won't start if the fuel pump isn't running. An easy way to check is to stick your ear against the fuel tank and turn the ignition key to on. You should hear the fuel pump make a whirring noise as it primes. I haven’t touched the tank. Thanks for your insight, that is good to know.
av8er
Post by av8er on Jan 23, 2018 5:41:05 GMT -7
Have you lifted up the tank recently? If so it is possible the plug for the fuel pump that fits into the bottom of the tank wasn't connected. The bike will crank but won't start if the fuel pump isn't running. An easy way to check is to stick your ear against the fuel tank and turn the ignition key to on. You should hear the fuel pump make a whirring noise as it primes. I haven’t touched the tank. Thanks for your insight, that is good to know. But you do hear the fuel pump prime? I know you stated the fuses were all checked.
Post by Deleted on Jan 23, 2018 13:49:33 GMT -7
New battery...all fuses look ok... The dealer will pick it up this week, hopefully this will be covered under a warranty. By the way I called a local dealer...the guy asked me to take my bike to the NY dealer I got it from (I am in NJ) ... then I called Motorcycle Mall...they will pick up my bike free if change! This happened to me once, I turned off, removed key, inserted it again and jiggled it and then started right up. Has not happened since in 6500 miles. Good luck with it and update us on what it turns out to be Tom
nedfeliciano
Post by nedfeliciano on Jan 23, 2018 15:34:13 GMT -7
New battery...all fuses look ok... The dealer will pick it up this week, hopefully this will be covered under a warranty. By the way I called a local dealer...the guy asked me to take my bike to the NY dealer I got it from (I am in NJ) ... then I called Motorcycle Mall...they will pick up my bike free if change! This happened to me once, I turned off, removed key, inserted it again and jiggled it and then started right up. Has not happened since in 6500 miles. Good luck with it and update us on what it turns out to be Tom Thanks Tom, I will keep you posted!
Post by RedAndBlack on Jan 24, 2018 0:03:43 GMT -7
I would bump start it to see if it fires. I had an older bike I couldn't get started and finally bump started it And then it was completely fine after that. Figured maybe it was vapour locked or something.
Other than that and maybe checking the voltage or the battery again just to be absolutely sure, I'd bring it to the dealer if it's under warranty which sounds like it might still be. Good luck and let us know for sure.
nedfeliciano
Post by nedfeliciano on Jan 24, 2018 8:18:23 GMT -7
I haven’t touched the tank. Thanks for your insight, that is good to know. But you do hear the fuel pump prime? I know you stated the fuses were all checked. I am not mechanicaly inclined...I don't know about that one. The bike is being picked up today....let's what they found. Thanks
nedfeliciano
Post by nedfeliciano on Jan 24, 2018 10:24:17 GMT -7
nedfeliciano
Post by nedfeliciano on Jan 28, 2018 13:13:46 GMT -7
I got my bike back, no issues according to the dealer. All they did was to charge the battery, apparently that was the issue even though the battery was new. That was so weird, I even charged the old battery with no success. Well I am glad I got it, I am ready to ride this week... I got my electric heated gear ready. Thanks for your comments and feedback friends.
Post by heathhudnall on Jan 28, 2018 18:35:14 GMT -7
I got my bike back, no issues according to the dealer. All they did was to charge the battery, apparently that was the issue even though the battery was new. That was so weird, I even charged the old battery with no success. Well I am glad I got it, I am ready to ride this week... I got my electric heated gear ready. Thanks for your comments and feedback friends. Glad you got it lined out.
jaxrider
Post by jaxrider on Jan 28, 2018 19:57:07 GMT -7
I had the same issue, two weeks after I bought it the battery went totally dead. After a long discussion with the dealer they warrantied it.
ikranmakto
Post by ikranmakto on Jan 28, 2018 23:21:33 GMT -7
Good to hear you have the problem sorted nedfeliciano Just a quick question though, You didn't turn the key all the way to "P" after you came back from a ride did you? At the risk of sounding like Captain Obvious, this is a known fault with the MT10 that drains the battery, most times beyond repair. Turning the key past the Lock position to P activates the electronics by which you can use the hazard lights etc:
nedfeliciano
Post by nedfeliciano on Jan 29, 2018 0:22:36 GMT -7
Good to hear you have the problem sorted nedfeliciano Just a quick question though, You didn't turn the key all the way to "P" after you came back from a ride did you? At the risk of sounding like Captain Obvious, this is a known fault with the MT10 that drains the battery, most times beyond repair. Turning the key past the Lock position to P activates the electronics by which you can use the hazard lights etc: No I didn’t. Part of the problem was caused by me having two bikes... most of the time I was riding my VFR (better gas mileage), by the time I got the battery tender the battery was not good anymore. The bike was parked in the lock position all the time.
daveinwoodland
Post by daveinwoodland on Jan 29, 2018 13:47:58 GMT -7
Glad it was an "easy" fix, now get out there are ride that thing!
