fzwaffle
Post by fzwaffle on Dec 30, 2017 10:36:59 GMT -7
Did not have my Battery tender hooked up and the bike sat for about a month with no starts/charging.
Just hooked it up and now there is consistent beeping coming from about 6 inches in front of the battery. Beeping is not coming from the battery tender. I've never seen this, I searched a few motorcycle forums.
Is this normal?
Post by evitzee on Dec 30, 2017 15:45:42 GMT -7
I'd disconnect the battery and see if the battery will come back to life by recharging. The electronics may just be seeing low voltage right now and will reset when a fully charged battery is reconnected.
sam07
Post by sam07 on Dec 30, 2017 17:18:48 GMT -7
Was the key in the off or park position? Park will drain your battery in a few days.
Definitely fully charge your battery first.
fzwaffle
Post by fzwaffle on Dec 30, 2017 17:56:05 GMT -7
I was in park, I ran a battery test. Its fried after 2700 miles and two weeks of park, had a bad cell. Went to get a replacement and the terminals were in the wrong spot. Never easy.
Post by papawheelie on Dec 30, 2017 18:12:14 GMT -7
Ha! I feel this same way sometimes, and wonder if it’s just me. Do I make things harder than they need to be?? Sorry for your trouble today, but it makes me feel better that it’s not just me. 😉
sam07
Post by sam07 on Dec 30, 2017 18:21:48 GMT -7
The Park position strikes again! Oh yeah you killed it good. There’s no way I would trust that battery.
Since your looking at it and I’m too lazy to remove my seat as I’m drinking a beer in front of a fire. What’s the stock CCA?
Post by evitzee on Dec 30, 2017 20:22:59 GMT -7
Stock battery is a Yuasa YTZ10S, 190 CCA
fzwaffle
Post by fzwaffle on Dec 31, 2017 12:41:32 GMT -7
Stock battery is a Yuasa YTZ10S, 190 CCA With the right positive terminal
fzwaffle
Post by fzwaffle on Dec 31, 2017 12:44:34 GMT -7
Post by evitzee on Dec 31, 2017 13:29:22 GMT -7
The + terminal is on the left, as pictured. Sounds like yours is installed backwards or you have a battery that has terminals reversed. What model number is on the battery?
fzwaffle
Post by fzwaffle on Dec 31, 2017 14:51:02 GMT -7
Got the correct battery, all is good now.
