Post by 0002s on Jan 27, 2018 7:51:48 GMT -7
ASV here, no issues
dewaynehasty
Post by dewaynehasty on Feb 9, 2018 17:55:26 GMT -7
I ordered these Chinese knockoffs for $25 shipped. Received them no problem. Quality looked great. But the clutch lever didn't fit properly. The slot where the cable end inserts in was too far from the edge of the lever. Also the tab that pushes on the sensor switch was just barely long enough; much shorter that the tab on the stock lever.
I don't recommend these. The seller is CrazyQueen-2016.
dewaynehasty
Post by dewaynehasty on Feb 14, 2018 19:45:49 GMT -7
What do they say "A poor man buys it twice." Well in my case three times Lesson learned watch out for the cheap ebay levers.
The sliver clutch is the stock unit. Middle unit is from CrazyQueen-2016. The part that impacts the clutch sensor is too short on this unit. Third unit is from MZS. On this unit the hole that the bolt goes through is too small. Plus the section that the bolt goes through is too thin.
Silver unit is stock Middle unit is MZS. The hole is too small. Bottom unit is from Crazy_Queen-2016. The hole that holds the clutch cable is too far from the edge of the clutch. The cable won't reach it.
