Post by RedAndBlack on Jul 10, 2017 13:19:01 GMT -7
Hello Everybody, I'm looking for aftermarket Levers but I keep hearing rumblings of compatibility issues.
The CRGs, I was told that the clutch lever is having issues with the clutch switch. I contacted CRG but nobody has gotten back to me.
Today I was reading that ASVs might have an issue with the cruise control.
Can you guys confirm what levers your using and any/or lack of compatibility issues? I guess from here I'm going to check out the Pazzos
Post by Deleted on Jul 10, 2017 13:41:08 GMT -7
Running pazzo and work great
Post by RedAndBlack on Jul 10, 2017 13:45:59 GMT -7
Running pazzo and work great Any recommendation on who to get them from? My regular supplier doesn't sell them.
Post by Deleted on Jul 10, 2017 15:24:02 GMT -7
miglo
Post by miglo on Jul 10, 2017 15:48:19 GMT -7
ASV work great...But that's the first I've heard of the CC issue?
Post by evitzee on Jul 10, 2017 19:08:37 GMT -7
Yamaha slightly changed the clutch lever dimensions a year or so ago, so previous levers which fit the older style design have a clearance issue with the new ones which prevent the clutch lever from closing completely. This could cause a problem with the cruise control. ASV knows all about this and changed the lockout tab to work with the new design, however there were still old style levers in the pipeline in early 2017. They should all be cleared out by now, but if you happen to get one of the older designs just call ASV and they will rush a new tab to you which is a two minute installation. I have ASV's and just removed the old tab and installed the new one they sent me, problem solved. I've had three sets of ASV levers on bikes and have never had a problem with them, and they don't fade or get chalky like a lot of the cheap Chinese ones do.
pancake
Post by pancake on Jul 10, 2017 19:56:02 GMT -7
I bought MZS shorty levers off eBay last September. They look great, work perfectly and are inexpensive.
usarmyk9
Post by usarmyk9 on Jul 11, 2017 2:48:19 GMT -7
I picked up a set of Vtrec levers for my bike. They're just as nice as the FP Racing levers I had on another bike. No fitment issues at all. www.v-trec.com/en/
maddogc5
Post by maddogc5 on Jul 11, 2017 20:43:37 GMT -7
Pazzo levers here too.. great levers.
Post by Deleted on Jul 12, 2017 7:06:37 GMT -7
Evotech on mine and they work great. I have a barely used Evotech black adjustable/folding brake lever for the FZ-10. PM me if you want it. You can order the clutch side directly from them to make the set. I have the brake lever lying around because I swapped to an R1 master after I got the lever. Doh. I did run it for a short while with the FZ-10 master and Evotech lever - everything worked fine.
audiblepop94
Post by audiblepop94 on Jul 26, 2017 11:36:57 GMT -7
ASV full length levers, over 1000 miles on em no issues.
Post by RedAndBlack on Jul 26, 2017 11:49:33 GMT -7
ASV full length levers, over 1000 miles on em no issues. That's what I settled on! I haven't used the brake lever yet because I'm waiting to do the R1 Master Cylinder Swap, but clutch lever seems all good.
dambikeracer
Post by dambikeracer on Aug 14, 2017 20:53:49 GMT -7
I got CRG's and had to modified the clutch lever with a dremel. Just looked at the stock lever and made the new lever look like the stock one. It was easy, took about two minutes. It's on the bottom side and you'll never see it.
miyong76
Post by miyong76 on Aug 15, 2017 11:17:44 GMT -7
I got CRG's and had to modified the clutch lever with a dremel. Just looked at the stock lever and made the new lever look like the stock one. It was easy, took about two minutes. It's on the bottom side and you'll never see it. Do you have a link or part number for the clutch side im using crg on the brake side because i use r1 master cylinder
Post by RedAndBlack on Aug 15, 2017 14:48:12 GMT -7
I got CRG's and had to modified the clutch lever with a dremel. Just looked at the stock lever and made the new lever look like the stock one. It was easy, took about two minutes. It's on the bottom side and you'll never see it. Do you have a link or part number for the clutch side im using crg on the brake side because i use r1 master cylinder I would call CRG and see if they fixed it yet. Last I heard when I originally posted this a while ago, they were waiting to get another FZ-10 back in the shop so they could fix it.
sc
Post by sc on Sept 18, 2017 15:07:28 GMT -7
The MZS didn't work well for me. Installed them and they threw a code. Haven't brought it to the dealer yet to figure out the reason as I just installed them today.
fzwaffle
Post by fzwaffle on Sept 18, 2017 17:06:07 GMT -7
I got CRG's and had to modified the clutch lever with a dremel. Just looked at the stock lever and made the new lever look like the stock one. It was easy, took about two minutes. It's on the bottom side and you'll never see it. I had to do the exact same thing to my CRG clutch lever, great feel though.
sc
Post by sc on Sept 20, 2017 16:11:32 GMT -7
Belay my last. Went to the dealership and had them get rid of the code. Turns out it was ACTUALLY the wheelie.. someone..did after the levers to see if the clutch was slipping. The front wheel slowed down to cause a "mismatch speed" between front and rear wheels. Levers are all good. Just wanted to clarify...
doctorzoidberg
Post by doctorzoidberg on Sept 22, 2017 6:02:00 GMT -7
Belay my last. Went to the dealership and had them get rid of the code. Turns out it was ACTUALLY the wheelie.. someone..did after the levers to see if the clutch was slipping. The front wheel slowed down to cause a "mismatch speed" between front and rear wheels. Levers are all good. Just wanted to clarify... I can confirm that MZS levers work well.
scribbler
Post by scribbler on Jan 26, 2018 4:39:16 GMT -7
I bought MZS shorty levers off eBay last September. They look great, work perfectly and are inexpensive. Hi do they operate the micro switch on the clutch ok as i bought one set off ebay and they didn't work right no criuse or quickshifter worked!
