mala
Post by mala on Jun 9, 2017 18:41:52 GMT -7
400 miles and the rear break is squeaking and when I release the rear brake I hear a heavy click sound. Any ideas or thoughts?
mala
Post by mala on Jun 10, 2017 16:21:50 GMT -7
Nothing, no one, nada? lol
Post by 0002s on Jun 10, 2017 16:55:30 GMT -7
Take pads out and put them back in. (Easy to do see tech tip section for instructions)
Post by Cruizin on Jun 10, 2017 17:09:54 GMT -7
Take pads out and put them back in. (Easy to do see tech tip section for instructions) When you take them out, check the pads to see if you have glazed any of the pads over with excessive braking. If any of the pads are glazed, you can sand em down carefully but its better to just replace them. Also, the squeaking could come from dust or particles being on the pads. HAs it been doing it for a while?
mala
Post by mala on Jun 11, 2017 8:01:11 GMT -7
Take pads out and put them back in. (Easy to do see tech tip section for instructions) When you take them out, check the pads to see if you have glazed any of the pads over with excessive braking. If any of the pads are glazed, you can sand em down carefully but its better to just replace them. Also, the squeaking could come from dust or particles being on the pads. HAs it been doing it for a while? Will give it a go gives me something to do today. I can honestly say I doubt very much it could be due to excessive braking as I hardly ever use them. All most all of my slowing is engine breaking and using brakes the last 10 to 0 mph to stop. It has been doing it for the last 100 miles I would say and only under 10mph to stop then when I release the rear brake there is a clear soft "thunk" sound.
Post by Cruizin on Jun 11, 2017 10:16:58 GMT -7
Then I would have to guess dirt is the culprit. Hose it all off real good. if that doesnt do it then stop by the dealer and have em take allok and then let us know.
mala
Post by mala on Jun 30, 2017 12:14:38 GMT -7
operationfz
Post by operationfz on Jun 30, 2017 15:41:56 GMT -7
I'm willing to bet a rock got stuck in there and caused havoc on the rotor.
mala
Post by mala on Jun 30, 2017 17:20:48 GMT -7
I'm willing to bet a rock got stuck in there and caused havoc on the rotor. I would agree if it was a gouge but I do not believe a rock would cause a raised line without deforming the sides of the raised shown. That is my guesstamation anyway. lol The "milling defect from factory" was said by the dealership so I have no clue to be honest. Now we have to wait and see if Yamaha will fix it.
Post by 0002s on Jun 30, 2017 17:40:25 GMT -7
Glad it got fixed at no cost.
mala
Post by mala on Jul 10, 2017 16:29:52 GMT -7
Glad it got fixed at no cost. Yamaha not only said they are going to fix it but that I am not the first one with this problem. At least Yamaha stood up. woot woot
Post by 0002s on Jul 11, 2017 9:56:24 GMT -7
Glad it got fixed at no cost. Yamaha not only said they are going to fix it but that I am not the first one with this problem. At least Yamaha stood up. woot woot They are #1 for a reason.
