motomodo
Post by motomodo on May 27, 2017 19:42:26 GMT -7
Does any one know what the torque spec is for the front motor mounts. I am installing sliders. The dealer said that it is 14 ft.lbs. That seems a big low. If anyone knows the correct spec I'd appreciate the help. Thanks in advance!
Post by evitzee on May 27, 2017 22:18:10 GMT -7
As you suspect, the dealer is incorrect. According to the Service Manual the engine bolts should be torqued to 70 Nm, or 51 lb-ft.
motomodo
Post by motomodo on May 28, 2017 16:57:59 GMT -7
Thanks a lot, big difference between the two!
