jerkychew
Post by jerkychew on May 19, 2017 5:22:08 GMT -7
Hi, I commute about 50 miles each way to work. I carry a pretty large backpack with me that has my laptop and accessories as well as gym clothes. I'm looking for a way to transport the bag to work on my FZ-10 without wearing it while riding. I picked up a set of the SW-Motech bags from France, but that was a big mistake as my laptop just won't fit in the bags and honestly it's just not a good solution for this particular scenario. The backpack is large, about 19"D x 11"W x 16"H and weighs, I don't know, around fifteen pounds when packed.
The SHAD side cases would do what I want but they're just so damn big. Plus I already spent a bunch of money on the SW-Motech bags, so I'm not ready to pull the trigger on another set of saddlebags yet. I don't think this backpack would fit on the tank so that's mostly out, so I have a few choices left that I'm aware of - Get a top rack for the rear and a small case for the backpack, or get a new backpack that'll mount to the top rack, or some other combination that I'm missing.
I wasn't even aware that I could mount bags to a top rack using the SW-Motech quick release system designed for the tank, so rather than spend hours reading about every dang combination I figured I'd ask you guys - Can you recommend some kind of backpack that I could mount to the bike, or a good top case that I could use to transport my existing backpack for my daily commute?
Post by Deleted on May 22, 2017 6:00:15 GMT -7
I'm running a SW Motech top case rack and a Givi V47 MonoKey top case. It's not a cheap solution but it offers some benefits.
-The top case is locked shut and is also locked to the bike. -Weatherproof -You'll use it for other things. Bike cover, weekend trips etc. -Top case can be easily removed and taken into work. -Frees up space on the seat for a passenger or another smaller bag.
The SW Motech rack weighs 8lbs with the MonoKey adapter plate. I don't mind the way it looks.
Post by 0002s on May 22, 2017 7:31:37 GMT -7
jeffinpdx
Post by jeffinpdx on May 22, 2017 9:44:55 GMT -7
...I picked up a set of the SW-Motech bags from France, but that was a big mistake as my laptop just won't fit in the bags and honestly it's just not a good solution for this particular scenario. The backpack is large, about 19"D x 11"W x 16"H and weighs, I don't know, around fifteen pounds when packed.... Which bags did you pick up? They make several models, and I was thinking about buying them for my bike. If they're the right ones, and you want to sell them, I might take them off your hands.
Post by 0002s on May 22, 2017 11:10:33 GMT -7
Motech Panniers MacBook Air vertical (Fits) Older MacBook Pro 15" vertical (close but does not fit) Older MacBook Pro 15" tilted slightly (Fits) Older MacBook Pro 15" tilted slightly with extra stuff (Fits)
