pancake
Post by pancake on Apr 25, 2017 6:57:04 GMT -7
Has anyone changed out their clutch cable to a longer one? Having to push the cable out of the way to insert the key is really starting to annoying me now and I want to re-route the cable properly out of the way. Not to mention that others have noticed it's binding/rubbing away against parts of the frame in the "Clutch Cable Recall Needed" thread.
So, has anyone changed theirs out yet? If so, what did you get ? any pics ? and/or what length cable did you use?
audiblepop94
Post by audiblepop94 on May 9, 2017 7:23:00 GMT -7
Same issue, almost too short at full turn. Kind of annoying for a new bike...
Post by evitzee on May 9, 2017 9:16:30 GMT -7
I have heard it is due to the cable sliding down a bit, if you pull up on it where it goes through the cable guide on the right side it will readjust itself. I've never had the problem but worth a 2 minute exercise to see if it would help the problem.
elfboy26
Post by elfboy26 on May 11, 2017 7:23:40 GMT -7
I installed Rox bar risers due to my short "T-Rex" arms. Everything was pretty easy to reroute except for the clutch cable. The way I have it works but a longer one would be better. Anyone know where to source one?
h19hsp33d
Post by h19hsp33d on Aug 2, 2018 21:02:42 GMT -7
I installed Rox bar risers due to my short "T-Rex" arms. Everything was pretty easy to reroute except for the clutch cable. The way I have it works but a longer one would be better. Anyone know where to source one? Bought some Rox risers and given up hope of an easy install. Any tips or photos from your install?
dashiznit1
Post by dashiznit1 on Dec 16, 2019 9:44:25 GMT -7
I installed Rox bar risers due to my short "T-Rex" arms. Everything was pretty easy to reroute except for the clutch cable. The way I have it works but a longer one would be better. Anyone know where to source one? Bought some Rox risers and given up hope of an easy install. Any tips or photos from your install? Its been a while but I'll bump this one, still haven't found any good tips on it and I'm having the same problem.
jd41
Post by jd41 on Dec 16, 2019 16:01:49 GMT -7
If clutch cable length is really the issue you can just buy a longer cable... www.venhill.co.uk
mattemike
Post by mattemike on Dec 18, 2019 5:43:37 GMT -7
Motion Pro will also make custom cables.
