daveinwoodland
Post by daveinwoodland on Apr 5, 2017 16:36:48 GMT -7
Not a huge deal so don't worry. Brought my bike in for the first service and they said there was an active bulletin to re-program the side stand software. (I'm guessing just the stand down stand up triggers) I asked but he said they didn't mention the exact reason just to reset some internal software setting.
Post by evitzee on Apr 5, 2017 17:15:48 GMT -7
That bulletin has been discussed previously. There are two switches that need to be closed in the ignition switch assembly.....one turns on the ECU, the other triggers the side stand/neutral clutch lockout circuit. If you turn the key too slowly the ECU turns on before the second switch is closed and the ECU sees a fault and you get a 'check engine' type light on the dash. Evidently the newer electronics turn on the ECU very quickly compared to older versions. Only way to clear it is to reprogram the ECU, that is what the bulletin does. It reprograms the logic so the ECU gives more time for the second switch to be closed. Yamaha dealers are very familiar with it.....they have a database which they log onto and it tells them if any outstanding bulletins or issues apply to any particular bike. Takes about 30 minutes.
Post by Deleted on Apr 5, 2017 17:21:24 GMT -7
Waiting to hear if the this will mess up my current flash.
spartanadv
Post by spartanadv on Apr 5, 2017 18:09:54 GMT -7
Waiting to hear if the this will mess up my current flash. Had this issue. Easy fix. Turn the key all the way like normal, wait for lights to clear, start bike. Do it any other way on mine, CEL comes on. Doesn't do anything if it does come on, just start the process as I stated. Your bike though; it will blow up. Lol.
Post by Deleted on Apr 5, 2017 18:21:00 GMT -7
Nope. You have the extra connection I hear your bike ticking from here. LOL
Have yet to have this fault myself
spartanadv
Post by spartanadv on Apr 5, 2017 18:48:25 GMT -7
Nope. You have the extra connection I hear your bike ticking from here. LOL Have yet to have this fault myself I'm going to steal your right rearset for that.
elfboy26
Post by elfboy26 on Apr 6, 2017 12:14:31 GMT -7
Picked up my FZ-10 on 3/28. It had just arrived at the dealer. They did the fix while I was finishing the paperwork.
Post by 0002s on Apr 6, 2017 12:21:43 GMT -7
Had it done and did not effect the tune. QS light still on and no effect in power.
