tj
Post by tj on Apr 1, 2017 9:32:48 GMT -7
Has anyone found a good fuel tank grip pad for the side of the tank.
k1kingdom
Post by k1kingdom on Apr 4, 2017 9:11:17 GMT -7
k1kingdom
Post by k1kingdom on Apr 4, 2017 9:15:34 GMT -7
Try TST industries.www.tstindustries.com. They have pads for the FZ10. I just ordered some a few days ago. Easy to install and they look really good. Give them a try.
pancake
Post by pancake on Apr 4, 2017 11:27:43 GMT -7
For the tank side grips, I have the Eazi-Grip Pro tank grips on and work well...there are 2-pieces per side, but kind of hard to see in the picture with a black bike. I believe R&G tank grips are identical. I also use the TechSpec Snake Skin Center Tank Pad, and I think they also now make side grips as well.
tj
Post by tj on Apr 6, 2017 20:08:36 GMT -7
that's great thanks for the info
daveinwoodland
Post by daveinwoodland on Apr 7, 2017 13:01:45 GMT -7
Tech Spec has an entire kit available for either the snakeskin style or the new pattern they have. If you get the snakeskin style they also include a center pad for the front of the tank. I have the Tech Specs on mine and they work well, just be aware that when they say it should be 70 degrees or above when installing them they mean it. A hairdryer also works but I've seen problems using that method. They had to replace my tank pad twice now because of an adhesive issue but on the flip side at least if you ever have to remove them they come off easy.
pancake
Post by pancake on Apr 11, 2017 7:16:46 GMT -7
Yeah agreed, for any brand of tank grip/pad make sure to properly clean your tank and use a heat gun on the tank and pad to get them hot before applying; don't just stick it on cold.
