Post by 0002s on Mar 11, 2017 15:56:55 GMT -7
Puig Oil Fill Cap (RevZilla link below for purchase) www.revzilla.com/motorcycle/puig-oil-fill-cap-yamahaOk you really don't need this as the OEM cap works but it is functional bling. Comes in five color options. It comes with a L bracket to mount to case for track day wire. It uses a 12mm socket for tight/remove. There is a 2.5mm Allen screw which locks a plate with a hole in it for track day wire. It comes with an installed gasket. Packaging is nice, but there are no stickers. It provides safety for you oil fill hole. It would be almost impossible to gain access to the fill hole without tools. For a wire I suggest getting a heavy duty twist tie and stripping the covering off. Install and cut to length. Finish is a heavy anodized color. If there is one complaint it's that the 12mm socket will wear the finish on the nut. You can't see this because the plate covers the nut.
Post by evitzee on Mar 11, 2017 19:38:23 GMT -7
Nice looking cap. I had a Yoshimura cap I ran on my previous FZ1 with absolutely no issues. Transferred it to my FZ-10 (same thread dimensions) and immediately had blow by which made a mess of the engine case and muffler. Evidently the crankcase pressure in the cross plane engine is higher. I'm going to try a different o-ring washer to see if I can stop the leakage. Just a thought to keep in mind on a seemingly simple part like this.
Post by 0002s on Mar 11, 2017 19:52:33 GMT -7
No issues after about an hour ride tonight. I'll let you know if I have an issue.
