chambers12
Post by chambers12 on Jul 10, 2017 18:47:00 GMT -7
Well if the fz09 blaster is simple put new plug on i will run that. Take mine off the 9 and maybe wire the 10 on there. Alabama laxed on everything. normally dont run blinkers.
djstraub
Post by djstraub on Feb 12, 2018 7:02:15 GMT -7
I bought the DMP integrated taillight. I can’t get the blinkers to blink. I’ve been on the phone with DMP multiple times and they can’t figure it out, even sent me a replacement and I had the same problem. Anyone else having his problem? Do I need to change the relay, and if so where is it located ?
Post by Deleted on Feb 12, 2018 7:38:14 GMT -7
I bought the DMP integrated taillight. I can’t get the blinkers to blink. I’ve been on the phone with DMP multiple times and they can’t figure it out, even sent me a replacement and I had the same problem. Anyone else having his problem? Do I need to change the relay, and if so where is it located ? So did you plug the OEM blinkers back in and do they work? If not, fuse or relay check. Otherwise if they do work then sounds like a pin out issue, the rears only have two wires so should be easy the test. -Tom
djstraub
Post by djstraub on Feb 12, 2018 7:41:20 GMT -7
Yes I connected the OEM blinkers and they still work. Pin out?
Post by Deleted on Feb 12, 2018 9:23:13 GMT -7
Yes I connected the OEM blinkers and they still work. Pin out? making sure the correct wires go to the correct pins in the connector but there are only two in the rear blinkers so should be pretty easy to tell, did they come with OEM connectors or did you have to connect those? If it was a load issue they should at least light up, do the fronts flash when you have the new one connected? If not I would be concerned there was a wiring issue... IDK, it is pretty straight forward, assuming the tail and brake light work, did you mount it, could it be a ground issue? Can you put a meter on it while it is hooked up and check for voltage with flasher on?
djstraub
Post by djstraub on Feb 12, 2018 9:42:59 GMT -7
Yes I connected the OEM blinkers and they still work. Pin out? making sure the correct wires go to the correct pins in the connector but there are only two in the rear blinkers so should be pretty easy to tell, did they come with OEM connectors or did you have to connect those? If it was a load issue they should at least light up, do the fronts flash when you have the new one connected? If not I would be concerned there was a wiring issue... IDK, it is pretty straight forward, assuming the tail and brake light work, did you mount it, could it be a ground issue? Can you put a meter on it while it is hooked up and check for voltage with flasher on? DMP says it’s most likely a load issue. Ground is fine because the brake light works and I can connect the blinkers to the battery directly and they light up. Meter is reading 12’s when the fronts flash. The fronts flash quickly when the rears are NOT connected. When I connect the rears the blink slows down but doesn’t light up.
Post by Deleted on Feb 12, 2018 10:40:04 GMT -7
Did you splice in to the OEM harness in front of the resistor packs or behind it? I am pretty sure the OEM blinker harness has resistors so if the new ones have internal resistors could be too much load? Just a thought
djstraub
Post by djstraub on Feb 13, 2018 10:34:55 GMT -7
Did you splice in to the OEM harness in front of the resistor packs or behind it? I am pretty sure the OEM blinker harness has resistors so if the new ones have internal resistors could be too much load? Just a thought I’m tired of dealing with it. Sent back the DMP one and ordered the Blaster x. Hopefully I’ll have better luck with them
Post by Deleted on Feb 13, 2018 12:19:00 GMT -7
Did you splice in to the OEM harness in front of the resistor packs or behind it? I am pretty sure the OEM blinker harness has resistors so if the new ones have internal resistors could be too much load? Just a thought I’m tired of dealing with it. Sent back the DMP one and ordered the Blaster x. Hopefully I’ll have better luck with them Sorry bro, I know that shit get's frustrating! You will be happy with the Blaster.
Post by heathhudnall on Feb 13, 2018 15:48:38 GMT -7
I is the MotoDynamic integrated tail on my FZ1, so I went with them again on the FZ10. Great product and company.
xxscaxx
Post by xxscaxx on Feb 14, 2018 9:09:02 GMT -7
I is the MotoDynamic integrated tail on my FZ1, so I went with them again on the FZ10. Great product and company. My buddy has the MotoDynamic on his FZ-09, I just purchased this as well for my 10. I love that you have the option of clear or smoked, it has 36 LEDS (blaster has 32), and it has sequential signals. The sequential signaling makes it a bit more polished IMHO. Its also cheaper than the blaster. Nothing against the blaster as I know its a great tail as well, but have to praise the MotoDynamic piece.
Post by heathhudnall on Feb 14, 2018 9:54:22 GMT -7
I is the MotoDynamic integrated tail on my FZ1, so I went with them again on the FZ10. Great product and company. My buddy has the MotoDynamic on his FZ-09, I just purchased this as well for my 10. I love that you have the option of clear or smoked, it has 36 LEDS (blaster has 32), and it has sequential signals. The sequential signaling makes it a bit more polished IMHO. Its also cheaper than the blaster. Nothing against the blaster as I know its a great tail as well, but have to praise the MotoDynamic piece. I agree. MotoDynamic has great customer service as well. I had a flush mount signal giving me problems and they had another one at my door in 3 days. From California to Kentucky in 3 days...for free.
dewaynehasty
Post by dewaynehasty on Feb 14, 2018 10:55:21 GMT -7
My buddy has the MotoDynamic on his FZ-09, I just purchased this as well for my 10. I love that you have the option of clear or smoked, it has 36 LEDS (blaster has 32), and it has sequential signals. The sequential signaling makes it a bit more polished IMHO. Its also cheaper than the blaster. Nothing against the blaster as I know its a great tail as well, but have to praise the MotoDynamic piece. I agree. MotoDynamic has great customer service as well. I had a flush mount signal giving me problems and they had another one at my door in 3 days. From California to Kentucky in 3 days...for free. +1 for motodynamics. I have their integrated tail light on my Ninja and FZ10. Very easy to connect!
xxscaxx
Post by xxscaxx on Feb 15, 2018 9:11:18 GMT -7
My buddy has the MotoDynamic on his FZ-09, I just purchased this as well for my 10. I love that you have the option of clear or smoked, it has 36 LEDS (blaster has 32), and it has sequential signals. The sequential signaling makes it a bit more polished IMHO. Its also cheaper than the blaster. Nothing against the blaster as I know its a great tail as well, but have to praise the MotoDynamic piece. I agree. MotoDynamic has great customer service as well. I had a flush mount signal giving me problems and they had another one at my door in 3 days. From California to Kentucky in 3 days...for free. yup, gotta love USPS...I feel like every damn parts warehouse is in the west coast...and of course being in NY that usually means waiting a week plus for parts. Nothing like getting something in two days when its coming from CA.
Post by heathhudnall on Feb 15, 2018 9:13:09 GMT -7
I agree. MotoDynamic has great customer service as well. I had a flush mount signal giving me problems and they had another one at my door in 3 days. From California to Kentucky in 3 days...for free. yup, gotta love USPS...I feel like every damn parts warehouse is in the west coast...and of course being in NY that usually means waiting a week plus for parts. Nothing like getting something in two days when its coming from CA. Yessir!
sam07
Post by sam07 on Feb 16, 2018 11:18:09 GMT -7
Wow I’m impressed by the price point of the motodynamic. $89 Can you only order from them? I hate paying for shipping!
We need a group buy hint hint admins!
Post by papawheelie on Feb 16, 2018 12:23:02 GMT -7
I’m in for a group buy.
sam07
Post by sam07 on Feb 19, 2018 16:16:08 GMT -7
Might not be a group buy but today save 10% with coupon washington22. Just ordered mine.
Post by papawheelie on Feb 19, 2018 20:32:35 GMT -7
Might not be a group buy but today save 10% with coupon washington22. Just ordered mine. Good find sam07. And, thank you for sharing. Placed my order as well.
xxscaxx
Post by xxscaxx on Feb 19, 2018 20:58:01 GMT -7
I have the motodynamic installed in smoke if anyone is interested in pics. I will take some next time i’m at the shop.
