racer172
Post by racer172 on Mar 6, 2017 10:29:49 GMT -7
Took her out for the first time on our Sunday canyon run, pretty impressed with the power, she doesn't have my confidence in the handling department yet. So one thing I notice, and tell me if you guys notice this too, when we were in the fast high-speed sweepers (100+) the front end felt unstable & light which gave the rear end a wallow effect, almost like the bikes in the 80's did just before they got high-speed wobbles. Is this common on naked bikes because the front end is so light? or is it a setup issue? All my bikes have been sport/race bikes so this one is new to me. In the pack of bike below in my group we did the 2nd gear roll-on and the fz10 got the jump on all of them, kept the lead till I was pegged up in 6th then they all blew by. That should change a bit after I build her. One thing that was really fun was if I let her climb up in the power band in 2nd or 3rd gear the front will climb up as much as I allow her to do. That's fun to have on tap!
Post by 0002s on Mar 6, 2017 15:46:02 GMT -7
I had the same handling felling you described. Have you had the suspension adjusted to you? Do you weight over 200 lbs with gear? I ultimately installed the Stolec Penske Triple Clicker and front springs. That fixed it and then some. Totally confidence inspiring after upgrade. Review of Penske Triple Clicker: fz10.org/thread/667/penske-triple-clicker-spring-initial1-2-3 with lift front starting around 6k RPMs under full throttle.
racer172
Post by racer172 on Mar 7, 2017 10:05:29 GMT -7
cool, thanks for the info. No I haven't had my mechanic tune the suspension yet I weigh only 165 will all my gear on I will read that thread, thanks.
