sam07
Post by sam07 on Feb 17, 2017 18:26:35 GMT -7
jagermeister
Post by jagermeister on Feb 20, 2017 21:18:13 GMT -7
I just finished installing the Knight Designs footpegs on my bike 2 hours ago. Easy job, probably 30 minutes even including lowering the rear brake & shifter. They're well made, and look OEM.
@ 1 inch lower, the rear brake lever is lowered as far as it'll go without triggering the brake light. I may tweak the switch spring to allow a bit more downward movement, if necessary.
Just sitting on the bike in the garage, I can feel a big difference in comfort. I haven't had a chance to ride with them yet; will post again tomorrow.
jagermeister
Post by jagermeister on Feb 21, 2017 7:18:11 GMT -7
Here are a few pics comparing the OEM pegs to Knight's. About 1 inch lower, 1 inch longer, twice as wide, and obviously I got the rubber treads. Ground clearance shouldn't be affected much, since Knight designs doesn't install peg feelers.
sam07
Post by sam07 on Feb 21, 2017 8:23:27 GMT -7
Here are a few pics comparing the OEM pegs to Knight's. About 1 inch lower, 1 inch longer, twice as wide, and obviously I got the rubber treads. Ground clearance shouldn't be affected much, since Knight designs doesn't install peg feelers. Awesome feedback! I'm placing an order today. Thanks for the advise on the brake adjustment. They look like a big improvement for comfort. After acl knee surgery, a one inch drop makes a big difference.
landmark518
Post by landmark518 on Jul 12, 2017 8:09:43 GMT -7
Hello. Does anyone have any suggestions for lowering the passenger foot pegs by 1.5 to 2 inches? I finally got my girlfriend to start ridding with me bout she complains that her legs are cramped up so we can't do longer rides. Thanks for any suggestions.
av8er
Post by av8er on Jul 12, 2017 13:16:06 GMT -7
Hello. Does anyone have any suggestions for lowering the passenger foot pegs by 1.5 to 2 inches? I finally got my girlfriend to start ridding with me bout she complains that her legs are cramped up so we can't do longer rides. Thanks for any suggestions. Look online for OEM parts and then pull up the part number for FZ 09 cruiser rear pegs. It will drop it about 3 inches. I think $56 a piece. I haven't bought yet because I was waiting to go to the Yamaha dealer and measure the bolt width on both bikes. They are the same. I need to order as well. Stealership wanted $74 a piece to order.
mtneer
Post by mtneer on Jul 12, 2017 16:55:44 GMT -7
Twisted Throttle sells MFW Vario pegs don't know if the have them for the FZ10 but they make both rider and passenger pegs that lower and can moved forward with an eccentric adjuster.
landmark518
Post by landmark518 on Jul 13, 2017 5:21:54 GMT -7
Twisted Throttle sells MFW Vario pegs don't know if the have them for the FZ10 but they make both rider and passenger pegs that lower and can moved forward with an eccentric adjuster. Thanks man!
