510dan
Post by 510dan on Nov 22, 2019 11:51:42 GMT -7
Why not just cut the wires by the sensors and shrink-wrap them? Easier than getting to the connectors.
wodger63
Post by wodger63 on Nov 25, 2019 15:00:38 GMT -7
Why not just cut the wires by the sensors and shrink-wrap them? Easier than getting to the connectors. Connectors are readily accessible, even the one above the clutch with a bit of patience. If you don't do any irreparable damage, you can always return to stock if required. Plus when on selling the new owner gets a warm fuzzy feeling when they get all the unmolested OEM bits, even if like you they have no intention of using them.
510dan
Post by 510dan on Nov 25, 2019 18:32:02 GMT -7
Got em both without removing anything.
wjcbsr
Post by wjcbsr on Nov 27, 2019 21:13:55 GMT -7
Where did you get those blank-plugs at? Just a quick add. Using the blank plug, I filled the wire tubes with high temp silicone and plugged them into the open connectors that were left on the bike. img host
ballmead
Post by ballmead on Oct 23, 2020 23:00:12 GMT -7
Thank you OP for this.
My tuner recommended that I lift the tank to get to the RHS O2 sensor connector but I followed your guide and got it out in a flash.
It was honestly way quicker than I could get the supposedly easier LHS O2 sensor out.
maximus
Post by maximus on Oct 24, 2020 7:31:33 GMT -7
On the 2020 is it still necessary to remove the O2 sensors when you choose to “disable” them in the flash. Is this w Woolich or FT software? Other bikes O2 sensors are controlled by the ECU, & can have their function flashed off, but I’m new to the MT 10.
Post by willl84 on Dec 14, 2020 5:32:41 GMT -7
On the 2020 is it still necessary to remove the O2 sensors when you choose to “disable” them in the flash. Is this w Woolich or FT software? Other bikes O2 sensors are controlled by the ECU, & can have their function flashed off, but I’m new to the MT 10. I'd like to know this as well. I'm mailing my ECU in today
pfontainejr
Post by pfontainejr on Dec 14, 2020 9:30:50 GMT -7
On the 2020 is it still necessary to remove the O2 sensors when you choose to “disable” them in the flash. Is this w Woolich or FT software? Other bikes O2 sensors are controlled by the ECU, & can have their function flashed off, but I’m new to the MT 10. I'd like to know this as well. I'm mailing my ECU in today If flashed by 2WDW then yes, you will need to remove or at least disconnect them.
Post by willl84 on Dec 14, 2020 12:52:47 GMT -7
I'd like to know this as well. I'm mailing my ECU in today If flashed by 2WDW then yes, you will need to remove or at least disconnect them. Alright thanks. I'll have to order some of those blanking plugs. i stull have the plugs for the exhaust that came with my system so I'm glad I hung onto them
maximus
Post by maximus on Dec 14, 2020 15:00:53 GMT -7
On the 2020 is it still necessary to remove the O2 sensors when you choose to “disable” them in the flash. Is this w Woolich or FT software? Other bikes O2 sensors are controlled by the ECU, & can have their function flashed off, but I’m new to the MT 10. I'd like to know this as well. I'm mailing my ECU in today I’ve been told by many you’ll need to unplug them from the harness w FT software. I haven’t spoken w my Woolich flash guy yet.
yamalove
Post by yamalove on May 3, 2021 17:48:58 GMT -7
I just removed the ecu and disconnected the O2 sensors And was extremely helpful based on the tutorial was laid out for us ... Thank you all for the input and the time ,pictures and comments...ECU on the way to the flashing master 2wdw Excited.
redlinez
Post by redlinez on Jul 18, 2021 17:26:51 GMT -7
The right side 02 sensor connector took me over an hour to get disconnected. There was no room and I had the hardest time getting it to rotate and show me the clip. I almost resorted to lifting the tank but did not give up!
goliath337
Post by goliath337 on Feb 26, 2022 20:43:36 GMT -7
