eardwulfarmida
Post by eardwulfarmida on Oct 21, 2024 7:59:10 GMT -7
Hey everyone, So I’ve been enjoying my Yamaha MT-10 for a while now, but recently I’ve run into an issue that’s been bugging me during my rides, and I’m curious if anyone else has experienced the same thing. Lately, while I’m out on longer rides—especially on routes with a lot of twists and turns—my GPS tracker seems to be showing inaccurate data or even dropping the signal entirely. I mainly use it to keep tabs on my speed, distance, and ride time, and I’ve noticed this happening more often in certain areas. It’s starting to make me question the reliability of my setup. For context, I rely on a GPS cycling tracker I’ve got installed on my bike. It’s not just a cycling tool, but something I’ve adapted for tracking my rides. A cycling tracker, for those who aren’t familiar, is typically used by cyclists to monitor various aspects of their rides like distance, speed, and elevation. Many riders use it as a how far did I bike today tool, which gives them precise data on their performance. I’m actually inspired by how accurate the tracking for cyclists is, especially on trails, and I thought it would translate well to motorbikes. And to be fair, it works great most of the time. But lately, I’ve found that when I’m in areas with heavy tree cover or lots of tall buildings, the GPS tracker seems to struggle. I’m pretty sure some of you out there are using similar tools, so maybe you can share some insights or experiences on this? One recent ride really highlighted the issue. I was riding through a forested, hilly area the other weekend, and my GPS dropped out completely for a solid 10 minutes. When it finally came back, it showed me way off from where I actually was on the route. That was pretty frustrating, because I usually rely on it for reviewing my ride data later. I’m starting to think it might be a signal strength issue, especially in areas with lots of interference from buildings or natural obstacles. So, I was wondering: do any of you use GPS trackers on your bikes? If so, have you encountered similar problems with signal loss or inaccurate data? How do you deal with it when your tracker gives you bad information? Do you have any tips for making it more reliable, or is this just something we have to accept in certain environments? I’ve thought about switching to a different GPS system or even tweaking my current setup, but before I go that route, I’d love to hear your thoughts and experiences. Maybe someone out there has figured out a better way to handle these signal drops? Any advice would be greatly appreciated!
871jz
Post by 871jz on Oct 21, 2024 11:11:12 GMT -7
The only form of GPS I use on my MT-10 is Google Maps (via my phone) for directions when I need them. No other use for me in terms of GPS on a motorcycle. Sorry, I can't help.
Post by RedAndBlack on Oct 21, 2024 13:04:36 GMT -7
Getting the obvious question out of the way, do you have the device installed where it has a clear line of sight to the sky? Like it's not under your seat or something?
Otherwise, I'd say it's likely your device considering that you're seeing these issues when you have obstruction over or around you. GPS requires a clear line of sight to available GPS satellites to provide GPS data. If a device has a weak signal or it does not have a very large network of GPS satellites that it can connect to, any obstruction may be a problem and trees may be enough of obstruction to cause this.
I've never had an issue with cell based GPS except for tunnels. One time I was in East bumblefuck San Diego county inside of canyons with cliffs on each side and no cell reception. We had a rider go off the road into a gulley. Zero cell phone service with no life for miles in any direction. Was still able to get a GPS location to give to a rider we sent up the road to call 9-1-1. As long as you can see some of the sky, you should normally be able to get a GPS signal no matter where you are.
