spaceninja
Post by spaceninja on Jul 6, 2024 17:25:18 GMT -7
has anyone put the gen1 saddlebags on a gen2 I plan on doing an ironbutt in about a month and would like to have the saddlebags to bring food and drinks with me
vulcanator
Post by vulcanator on Jul 10, 2024 18:29:51 GMT -7
I believe the rear subframe is a different design compared to the Gen 1 MT's. I don't think they would fit.
Post by willl84 on Jul 11, 2024 3:52:54 GMT -7
I believe the rear subframe is a different design compared to the Gen 1 MT's. I don't think they would fit. From what I've seen the gen 2 lacks the mounting points that the gen 1 has. Gen 1: notice the two horizontal mounting lugs on either side, right where the #10 is and then right at the back. Images were taken from the 2019 and 2023 model years ![](https://i.ibb.co/CnQKw3W/gen1.png) Gen 2 is missing those: ![](https://i.ibb.co/cQJ9kZf/gen2.png) Interestingly enough the side braces on the gen 2 are different - no lightening holes and slots. They're just solid except for one hole. also the center cross brace/mount is shaped differently and moved forward on the gen 2
northsouth
Post by northsouth on Jul 11, 2024 5:45:28 GMT -7
Thanks Yamaha. Dumbasses.
wintersdark
Post by wintersdark on Jul 24, 2024 20:29:17 GMT -7
Thanks Yamaha. Dumbasses. Yeah, it's frustrating. There are a couple bag options for the second gen, but very, very few, and those that do generally run a support back from the passenger peg mounts.
northsouth
Post by northsouth on Aug 8, 2024 17:52:23 GMT -7
![](https://i.ibb.co/1v4wzHd/IMG-1058.jpg) You can do it if you’re willing to do a little fabrication. Shad’s 1st gen rack will work with the factory Yamaha rack with some modifications. I’ll post details when it’s done. Not too difficult.
northsouth
Post by northsouth on Sept 2, 2024 16:30:57 GMT -7
![](https://i.ibb.co/vBVCW8S/IMG-1136.jpg) ![](https://i.ibb.co/6XrjWDR/IMG-1137.jpg) ![](https://i.ibb.co/hLrJwZY/IMG-1139.jpg) The side case rack is the 3P for the 1st gen from Shad. The topcase rack is the factory Yamaha rack that fits both gen’s. The front mount for the 3P is in the same location on both gen’s. The rear mount on the 3P used to have 2 bolt holes but the front facing one needs to be cut off with a grinder with a cut off wheel. Then just grind the cut edge smooth and paint with satin black rust oleum. Put the front mount bolt in the 3P rack and lightly attach it to the bike, rotate the rack up to meet the side of the Yamaha rack and mark the center of the bolt hole. Drill a 5/16” hole through the marked location (it’s solid aluminum and strong). Then bolt it up using Shad’s provided hardware. It was rock solid this way, but I made an additional mid point bracket out of 1/8”x1” aluminum stock I had laying around just because. It’s totally solid now and can hold either the SH23 bags or any of their larger bags if needed.
