xjr19
Post by xjr19 on Jun 5, 2024 0:37:53 GMT -7
Good days! My bike is a 2023 MT10. I want to lower the cooling fans start temperature point (the defult setting is 105 degrees Celsius). In addition to adjusters like woolich tuner, is there any other cheaper tuning software that can do this?
Because I don’t want to change the ECu mapping yet, I just want to run the fans in advance to increase heat dissipation.
Post by parthz8 on Jun 5, 2024 10:09:47 GMT -7
Hello... I dont think there is another "cheaper" way to tweak Temperature settings for turning On and Off radiator fans. I changed those setting on my R1M during tuning on ECU with Woolich. On my MT-10 SP 2023, not planning to change or tweak any settings. (No ECU Tuning - due to strict emission laws and noise restrictions by authority)
Post by mindcrime79 on Jun 5, 2024 13:07:31 GMT -7
Any competent tuner should be able to do this for $250 or less.
Post by willl84 on Jun 6, 2024 9:28:33 GMT -7
Pretty sure you could get the ECU flashed the same way but ask them to ONLY change the fan temps.
Back when I had my TLR one of the big mods was to put a manual switch somewhere for the cooling fans. Just wire it through a relay connected to a switched hot (like the power outlet) so the fans shut off with the key. The onyl issue with that on the MT is that the left fan turns on before the right one so you'd need a switch for both (or just switch one).
