zrider0321
Post by zrider0321 on May 5, 2024 18:30:24 GMT -7
Trying to buy the ultralight rear rotor from a Yamaha r1 2015+ and I’m wondering if it would fit in a mt10 first gen
Post by RedAndBlack on May 5, 2024 21:57:07 GMT -7
Welcome to the forum!
Should. Brake rotors are same part #. I don't know about the R1M thiugh.
Post by parthz8 on May 11, 2024 2:02:53 GMT -7
R1 and R1M (2015 - 2020) Rear Brake Disk rotor and rear Caliper are same. But MT-10 Gen-1 (till 2021) rear brake rotor and rear caliper are different from 2CR (R1/R1M). MT-10s have bigger rear brakes and P/Ns are different.
Front Brake rotors are same for R1/R1M and MT-10s but R1M front calipers are different to fit on Öhlins.
871jz
Post by 871jz on Aug 1, 2024 7:53:46 GMT -7
So is the rear rotor on the 2022+ MT-10 the same as the R1, or is it different?
EDIT: I just looked up the diagram and part numbers for the rear brake on the 2023 MT-10 and 2023 R1. The rear brake rotors are totally different, which is completely evident by not only the part numbers being different, but also the pictures. Not even close to being interchangeable. I also looked up a 2018 R1 and compared it to a 2023 MT-10. Again, they are different. Didn't bother looking up the older generation of MT-10 and comparing because I don't have one of those models.
Post by willl84 on Aug 1, 2024 11:51:27 GMT -7
EBC lists P/N MD2091 for both gens MT and MD2125 for the 15-19 R1 so yea, they're different
