spartanadv
Post by spartanadv on Dec 22, 2016 17:01:10 GMT -7
I rode a bit the other day and my gauge still read full. When I went to fill up, it took just a hair over 1.5 gallons. Anyone else have this issue or is there a fix for it?
Post by slv on Dec 22, 2016 17:12:30 GMT -7
Yes. Mine reads full, full, full, full, half, almost empty.
I haven't pushed past that,, but I've never been able to squeeze more than 3.8 gallons back into it.
The gauge is not accurate.
warnock
Post by warnock on Dec 22, 2016 17:37:52 GMT -7
I don't like the gas gauge myself, it's annoying not knowing when you are at 3/4 of a tank. Going from full to half stinks lol
spartanadv
Post by spartanadv on Dec 22, 2016 17:59:45 GMT -7
Do you think it's an ecu issue or some other issue?
Post by 0002s on Dec 22, 2016 18:05:39 GMT -7
FULL, full, 1/2, 1/4. Doesn't seem off on mine, but I fill at 1/2 to 1/4.
spartanadv
Post by spartanadv on Dec 22, 2016 18:46:31 GMT -7
FULL, full, 1/2, 1/4. Doesn't seem off on mine, but I fill at 1/2 to 1/4. I'll do that from now on.
Post by 0002s on Dec 22, 2016 19:01:31 GMT -7
FULL, full, 1/2, 1/4. Doesn't seem off on mine, but I fill at 1/2 to 1/4. I'll do that from now on. Around my parts it's about a $6.xx fill up at 1/4.
spartanadv
Post by spartanadv on Dec 22, 2016 19:17:12 GMT -7
I'll do that from now on. Around my parts it's about a $6.xx fill up at 1/4. It's around 2.68 a gallon here. Not too bad for premium.
mrhix
Post by mrhix on Dec 22, 2016 20:15:14 GMT -7
With stock ECU I got 70 miles to 1/2 tank, 100 miles to next mark, and 120 miles to the reserve. I put 140 miles on an early tank and filled it up with 4.2 gallons US.
Cheers,
MrHix
Post by tigershark on Dec 22, 2016 21:59:53 GMT -7
+1 to mr hix.
Unless something is way off on your particular -10, you're gonna get 120 miles till fill time. At approximately 60 miles, the gauge drops to half, at approx 90 miles 1/4 tank and at 120 reserve and low tank warning . 20-30 miles later, it's empty. This is typical and the gauge is not off, just different. Eventually it becomes second nature. Average gas mileage is 32-34 mpg per tank. Not unusual for a 160 hp motorcycle.
Post by slv on Dec 22, 2016 22:24:29 GMT -7
I don't think mine is off, just not reading in small enough increments. If I'm leaving one town and the next one is 60 miles away, I don't like the false sense of a full tank when it's really just a few miles from a half tank. I guess I'll get used to using a trip meter.
It's really not a big deal, but the device could be a lot better.
spartanadv
Post by spartanadv on Dec 26, 2016 23:05:24 GMT -7
+1 to mr hix. Unless something is way off on your particular -10, you're gonna get 120 miles till fill time. At approximately 60 miles, the gauge drops to half, at approx 90 miles 1/4 tank and at 120 reserve and low tank warning . 20-30 miles later, it's empty. This is typical and the gauge is not off, just different. Eventually it becomes second nature. Average gas mileage is 32-34 mpg per tank. Not unusual for a 160 hp motorcycle. My mpg stays at 29. As far as your assessment of the miles and the gauge, I tested it today and you are dead on! Mine did drop at those exact points. I'm happy. Lol.
Post by tigershark on Dec 27, 2016 7:20:55 GMT -7
So, given the capacity of the tank, you should be getting around 32-34 mpg as well. In 2100 miles, calculating at each fill up, I've had one tank go 35 mpg and have never been below 32 mpg. If I baby it for the entire tank, the miles are slightly higher as the gauge drops to each segment (roughly 5 more miles) and 35 mpg is the result. Overall, you'll be close on every tank unless you really flog it the entire time. This is very typical for the -10. I've read one post reporting mpg consistently in the low 20s. Be happy you don't have that bike.
Post by tigershark on Dec 27, 2016 7:43:28 GMT -7
One additional point about gas. I ran premium through the break in miles. I've since gone to one tankful of premium every 1000 miles and regular the rest of the time. The only real difference is premium has added cleaning agents. As clean as the -10 runs, it's overkill to run premium all the time. It runs exactly the same on regular. Same smoothness, power, gas mileage, engine temps, etc.
I do the same with our car and truck.
Post by slv on Dec 27, 2016 12:29:38 GMT -7
One additional point about gas. I ran premium through the break in miles. I've since gone to one tankful of premium every 1000 miles and regular the rest of the time. The only real difference is premium has added cleaning agents. As clean as the -10 runs, it's overkill to run premium all the time. It runs exactly the same on regular. Same smoothness, power, gas mileage, engine temps, etc. I do the same with our car and truck. Exactly. Octane has nothing to do with performance. It simply reduces detonation (ping.). If a motor doesn't ping with regular, premium is just spending money.
Post by Deleted on Dec 27, 2016 13:08:33 GMT -7
Does your regular have ethanol?
adamb
Post by adamb on Dec 27, 2016 17:51:14 GMT -7
Octane has everything to do with performance, if the timing is tuned for it. The detergents in 87 and 93 are in most cases the same. If you are concerned about detergents in gas then only use top tier fuel.
Post by slv on Dec 27, 2016 18:35:04 GMT -7
Octane has everything to do with performance, if the timing is tuned for it. The detergents in 87 and 93 are in most cases the same. If you are concerned about detergents in gas then only use top tier fuel. Yes, but the safe operating combustion at advanced timing creates the performance increase. The octane level affects the burn rate, which helps prevent detonation when timing is excessively advanced. High octane fuel doesn't increase performance; but it does allow engines to be tuned to a higher level of performance. My point is that simply using high octane fuel vs a lower octane fuel will not increase performance.
Post by slv on Dec 27, 2016 18:36:34 GMT -7
Does your regular have ethanol? Yes. Almost all the gas in my area has ethanol. There are a few places in the area selling ethanol free gas, but not many.
guywithfz10
Post by guywithfz10 on Dec 27, 2016 20:52:43 GMT -7
Does your regular have ethanol? Yes. Almost all the gas in my area has ethanol. There are a few places in the area selling ethanol free gas, but not many. Shell or Chevron premium gas isn't ethanol free in your area?
