mattesjl
Post by mattesjl on Jan 28, 2024 18:24:33 GMT -7
I took my rear wheel off, popped off the sprocket and took it to get a new tire on. Picked up be wheel and the spacer that ends the long sleeve inside the wheel doesn’t sit flush in the wheel. I’m pretty sure it was flush when I took it apart. Any ideas or pictures of the rear wheel with the sprocket assembly popped off?
treedogg
Post by treedogg on Jan 30, 2024 11:47:20 GMT -7
I personally am not sure, I had my first set put on by a shop and haven't needed another yet. Will be taking them off my self this year at some point but I don't think that will help you! Good luck
boilovepho
Post by boilovepho on Jan 30, 2024 16:03:34 GMT -7
It’s not flush. Once you install the actual wheel on, it will make sense. Take a pic for us to make sure though.
