robbo
Post by robbo on Nov 28, 2023 5:11:20 GMT -7
Hi Can anyone tell me if a speedo swap on my 2017 mt10sp would be straightforward or would it have to be programmed?
treedogg
Post by treedogg on Nov 28, 2023 8:16:26 GMT -7
Someone else on here did a speedo swap on a 2023 recently and it was a straightforward deal no programming required. I would assume the 1st gen would be the same.
robbo
Post by robbo on Nov 29, 2023 2:31:39 GMT -7
Thanks I will see if I can find hiss posting.
Post by willl84 on Dec 4, 2023 17:38:15 GMT -7
Should be a straight swap as long as you're replacing it with the same type (LCD-LCD or TFT-TFT). The mileage is stored in the gauges though so it'll be different
robbo
Post by robbo on Dec 13, 2023 10:54:30 GMT -7
Many thanks for you response guys think i will just have to buy one and give it a go.
