natesnick
Post by natesnick on Nov 5, 2023 11:31:27 GMT -7
I am looking to change chains in the upcoming months and I am looking for a chain conversion kit. I have only found one other thread with a link from 2wheel (can’t remember the rest) but a trusted website and I believe they flashed my ECU. Online I found this conversion kit and was wondering what you all think. stoltecmoto.com/shop/uncategorized/17-fz-10-520-chain-conversion-kit/Any and all advice would be welcomed. Thank you!
Post by RedAndBlack on Nov 8, 2023 16:43:51 GMT -7
Going off a recent threads up going up/down teeth, someone brought up that going too far would render the cruise control inoperable. It was a very recent thread so check the tech questions sub-forum for more info.
I have no personal experience with chain and sprocket conversion so unfortunately that's all I have to offer.
Stoltec Moto put a lot of effort into his FZ10 when he had it so anything he worked with was tested and true. I miss his threads.
Post by willl84 on Nov 10, 2023 4:56:59 GMT -7
natesnick
Post by natesnick on Nov 10, 2023 7:01:14 GMT -7
Thank you both I appreciate it. RedAndBlack there is an old forum member who lived in my area, heavily modded black FZ10/MT10 and I wonder if that was him.
natesnick
Post by natesnick on Nov 10, 2023 7:03:59 GMT -7
Will do you have any idea on the teeth sizes? Could stay OEM or change things? Id like a little more low end torque without completely messing up the top end. I don't really speed much but don't want to be miserable on the highway.
Post by willl84 on Nov 10, 2023 7:25:52 GMT -7
If you want more bottom end then go bigger on rear/smaller on front, but you'll lose top end speed. If you want top speed go smaller rear/bigger front. Stock is 16/43 (gen 1, gen 2 is 16/41 - same as R1) which is 2.6875 ratio so changing one front tooth is almost equal to going 3 on the rear. Ging from 16/43 to 16/45 for instance will drop your speed by about 3 MPH at 70. So factory at 70 MPH you'll be at about 67 MPH so not a huge drop, but acceleration will be a touch quicker and MPG's will go down because your revs will be higher in any given gear. Going to 16/41 for instance you'd be at about 73.4 MPH at the rame RPM that had you at 70 MPH with the stock 16/43 gearing. Good thing about these bikes is the speedo won't be off as it's read from the wheels not the countershaft sprocket like bikes used to. I used this neat calculator for it: www.blocklayer.com/chain-sprocket Stock tire OD is 24.8" for a 190/55-17.
natesnick
Post by natesnick on Nov 10, 2023 10:14:38 GMT -7
Sorry for all the questions Will. My last one for now.. do you think I'd need to re-flash the bike once the gearing is changed?
natesnick
Post by natesnick on Nov 11, 2023 8:44:33 GMT -7
Just when I thought my questions were done. When selecting the chains on the website some say 1000cc rated and some say 1200cc rated. I understand our bikes are 1000cc but does a 12000cc chain still work on our bike? I would assume it's perfectly fine just want to make sure.
Post by willl84 on Nov 13, 2023 6:35:34 GMT -7
Sorry for all the questions Will. My last one for now.. do you think I'd need to re-flash the bike once the gearing is changed? Good thing about these bikes is the speedo won't be off as it's read from the wheels not the countershaft sprocket like bikes used to. Just when I thought my questions were done. When selecting the chains on the website some say 1000cc rated and some say 1200cc rated. I understand our bikes are 1000cc but does a 12000cc chain still work on our bike? I would assume it's perfectly fine just want to make sure. They'll be just fine. I don't even bother with those ratings honestly. Back in the day the 1000cc bikes all came with 530 chains. My TLR made 125 at the wheel with exhaust/tune and stuff so noticeably less when stock. The MT makes much more than that at the wheel and comes with a 525 which is narrower by a smidge and plenty have done 520 kits (even more narrow still) with no problems.
natesnick
Post by natesnick on Nov 15, 2023 13:44:47 GMT -7
I appreciate the feedback. The website is a little off with their pricing. It’s 170$ with none of the options selected. You have to add a chain and that brings the price up a bit based on which chain you choose.
Post by willl84 on Nov 16, 2023 5:11:25 GMT -7
I appreciate the feedback. The website is a little off with their pricing. It’s 170$ with none of the options selected. You have to add a chain and that brings the price up a bit based on which chain you choose. Ah, missed that part. They offer the RK 520 MAXX natural for no additional charge. Others are like +$15 or +$25. But yea, there's some expensive chains in there lol
nokz
Post by nokz on Nov 20, 2023 2:53:37 GMT -7
I replaced mine from Sprocket Center. I went with....
520 Conversion Kit - SUPERLITE RSX Sprocket Set with Choice of Chain - YAMAHA MT-10 ('16-21) SL12A1024
CHAIN BRAND | MODEL | COLOR: DID 520 ZVMX - GLOSS BLACK Heavy Duty X'ring (1200cc rated) REAR SPROCKET SIZE: 43 Tooth - RXT Design STEEL FRONT SPROCKET SIZE: 16 Tooth - VORTEX
natesnick
Post by natesnick on Nov 20, 2023 7:05:23 GMT -7
I replaced mine from Sprocket Center. I went with.... 520 Conversion Kit - SUPERLITE RSX Sprocket Set with Choice of Chain - YAMAHA MT-10 ('16-21) SL12A1024 CHAIN BRAND | MODEL | COLOR: DID 520 ZVMX - GLOSS BLACK Heavy Duty X'ring (1200cc rated) REAR SPROCKET SIZE: 43 Tooth - RXT Design STEEL FRONT SPROCKET SIZE: 16 Tooth - VORTEX That’s stock gearing correct?
Post by willl84 on Nov 21, 2023 6:06:09 GMT -7
I replaced mine from Sprocket Center. I went with.... 520 Conversion Kit - SUPERLITE RSX Sprocket Set with Choice of Chain - YAMAHA MT-10 ('16-21) SL12A1024 CHAIN BRAND | MODEL | COLOR: DID 520 ZVMX - GLOSS BLACK Heavy Duty X'ring (1200cc rated) REAR SPROCKET SIZE: 43 Tooth - RXT Design STEEL FRONT SPROCKET SIZE: 16 Tooth - VORTEX That’s stock gearing correct? 16/43 is stock for first gen 16/42 is stock for second (corrected from 16/41 which is stock R1)
cowthulhu
Post by cowthulhu on Nov 21, 2023 10:00:08 GMT -7
That’s stock gearing correct? 16/43 is stock for first gen 16/41 is stock for second I thought 16/42 was second gen?
Post by willl84 on Nov 22, 2023 3:14:36 GMT -7
16/43 is stock for first gen 16/41 is stock for second I thought 16/42 was second gen? My bad, you are correct! I thought they dropped two teeth to match the R1 gearing but they only went one
