Post by mindcrime79 on Oct 30, 2023 11:18:49 GMT -7
Where do I find the cheap metal spring clips for rear brake pads? Parts diagrams only show one. There's two inside my caliper on 2017.
terrys
Post by terrys on Oct 30, 2023 12:36:34 GMT -7
Here's a link to the online parts catalogue on Partzilla. There's only one pad spring in that calliper. link
Post by mindcrime79 on Oct 30, 2023 12:40:06 GMT -7
The parts diagram is included on my original post. Below is the factory manual There's another that goes at the top of the caliper. I know this because I have it apart.
terrys
Post by terrys on Oct 30, 2023 20:17:53 GMT -7
I see what you mean now. The part shown in the parts diagram just supports the end of the pads against the caliper mount bracket. The spring you're referring to sits in the roof of the caliper, pressing down. If the parts fiche doesn't show it separately, you could conclude that you have to buy the whole caliper assembly, which would really suck. I looked at a few other fiches, the MT-07 does show the bit you want, separately. For $5.66 maybe you could try one of those? www.partzilla.com/product/yamaha/5SL-25919-00-00?ref=7668870a3b55ce60387c317228378682727117fe. That page shows that this part also fits the MT-10 rear caliper and is the same part number as the bit that you did not want. I'm confused...maybe Yamaha has a parts fiche error?
Post by mindcrime79 on Oct 30, 2023 22:01:44 GMT -7
Something is still not correct. If you click on the original part (#8) in the parts diagram for the mt10 or fz10 it shows one clip but the exploded diagram illustrates the other clip. Leading me to wonder what you are really getting for part number SL-25919-00-00... Basically Yamaha is showing two different photos of part SL-25919-00-00:
terrys
Post by terrys on Oct 31, 2023 20:46:40 GMT -7
I think Yamaha have a messed up parts diagram for the MT-10 and the part number cited is correct for the bit that you want, just the artwork is not right. The parts diagram for the MT07 has the correct picture which leads to a photo of the correct piece.
Post by mindcrime79 on Nov 2, 2023 0:13:49 GMT -7
Haha but how would I purchase both of these clips then?!!
terrys
Post by terrys on Nov 3, 2023 19:42:40 GMT -7
If you need both then it is probably easier just to buy a whole new MT-10...
