squiresca
Post by squiresca on Oct 9, 2023 6:51:15 GMT -7
The bike has plenty of poke obviously, especially with a pipe, filter and proper ECU flash and tune. But was thinking that I will never see 160+ on this thing, even on track. Just doesn't have the aero to get to that speed much, unless you have a long runway and like to be ripped apart by the wind...
So I figured that -1 up front would make it even more mental in the range where I spend most of my time, and at least by doing -1 up front, that allows me to move the rear wheel back a tad, which will help offset things a bit with regards to keeping the front end down...
Anyone made that change, and if so, how do you like it? For reference, I am almost 6'4" and 245lbs plus gear... So on a bike like this, I have no place to hide from the wind. haha
I ran the calcs on gearing commander and it seems to make sense to do on paper, but I know that what looks good on paper may or may not translate to the real world...
I usually try to gear my bikes so that if I was able to hit the rev limiter in 6th, what is the absolute fastest I am ever even remotely likely to go? And I gear for that. I also have a 2022 ZX14R flashed and tuned, and after fitting a taller 55 profile tire on the back, that raises my theoretical top speed to 211mph. Which I would never and could never hit... So I am doing a -1 front and +1 rear on that bike, to give it even more grunt down low, while limiting my theoretical top speed to "only" 193mph...
Post by RedAndBlack on Oct 9, 2023 7:21:34 GMT -7
I think given what you're trying to achieve, it's a good starting point. And you can always go up a tooth or two in the rear if you need, if it's too drastic of a change. But were most certainly talking about a 5% change in top speed, if that while achieving probably similar gain on torque, or at least lower end power.
I gotta admit, I've never messed with gearing, just pickup what I hear from my racer buddies when we go to the track. So I'm very novice when it comes to gearing so take my advice for what it's worth.
squiresca
Post by squiresca on Oct 9, 2023 7:33:14 GMT -7
I just notice that on my MT-10, it has tons of power, but it does like the clutch slipped a bit at launch and under 25mph... after that it has enough revs that it doesn't feel like its lugging the motor... Many of my Ducati's were like that... pulled like a freight train, but hating being under 3500rpm...
wintersdark
Post by wintersdark on Oct 9, 2023 9:37:42 GMT -7
A warning:
On the MT09 Tracer, going a front sprocket tooth is too much of a gearing change for the cruise control to continue working. There, +/-2 on the rear is the most you can do before cruise control will randomly shut off.
I would expect this to be the same on the MT10, having the same dash/CC setup, but have not tried personally.
squiresca
Post by squiresca on Oct 9, 2023 9:46:55 GMT -7
A warning: On the MT09 Tracer, going a front sprocket tooth is too much of a gearing change for the cruise control to continue working. There, +/-2 on the rear is the most you can do before cruise control will randomly shut off. I would expect this to be the same on the MT10, having the same dash/CC setup, but have not tried personally. Hmmm, that is something that I had not considered. Guess I will have to test and see what happens. I don't really use Cruise Control much, bit I don't want it to impact other things like traction control, slide or wheelie control... I had a Tracer 9GT a 2022... and I think I did the -1 front sprocket and didn't have any issues...
wintersdark
Post by wintersdark on Oct 9, 2023 12:25:50 GMT -7
Hmmm, that is something that I had not considered. Guess I will have to test and see what happens. I don't really use Cruise Control much, bit I don't want it to impact other things like traction control, slide or wheelie control... I had a Tracer 9GT a 2022... and I think I did the -1 front sprocket and didn't have any issues... Mine was a 2019 Tracer 900GT (2nd gen) for what that's worth, and it's happened that way on every 2nd gen I know of. Maybe it works differently in more recent setups, or maybe your particular bike was just more tolerant, either way just something to be aware of. Personally, I love CC - it's nice to give the hands a break on longer rides without needing a janky throttle lock! But to each their own, just be aware of the risk.
vulcanator
Post by vulcanator on Oct 16, 2023 13:20:56 GMT -7
If you're going to gear down, you can achieve that by putting a 43 tooth rear sprocket from the 2019 model. That would replicate the gearing of the 2016-2021 models. I have a 2019 model and I geared it up to match the 2022 model after my cat delete/ECU flash/AIS removal and it easily tops 160. The fact you're a larger lad has a bearing on your top end performance. Good luck with your plan.
squiresca
Post by squiresca on Oct 16, 2023 13:29:48 GMT -7
If you're going to gear down, you can achieve that by putting a 43 tooth rear sprocket from the 2019 model. That would replicate the gearing of the 2016-2021 models. I have a 2019 model and I geared it up to match the 2022 model after my cat delete/ECU flash/AIS removal and it easily tops 160. The fact you're a larger lad has a bearing on your top end performance. Good luck with your plan. I did -1 on the front sprocket and love it. Little more pep, really fun to ride and it didn't impact the cruise control at all, everything works fine... I regeared two of my bikes this weekend, but the latter half covers how the MT-10 is riding...
2wheeledprivilege
Post by 2wheeledprivilege on Oct 16, 2023 18:32:39 GMT -7
If you're going to gear down, you can achieve that by putting a 43 tooth rear sprocket from the 2019 model. That would replicate the gearing of the 2016-2021 models. I have a 2019 model and I geared it up to match the 2022 model after my cat delete/ECU flash/AIS removal and it easily tops 160. The fact you're a larger lad has a bearing on your top end performance. Good luck with your plan. I did -1 on the front sprocket and love it. Little more pep, really fun to ride and it didn't impact the cruise control at all, everything works fine... I regeared two of my bikes this weekend, but the latter half covers how the MT-10 is riding... I was just about to suggest this video, not realizing he was a member of the board....DOH!!
wintersdark
Post by wintersdark on Oct 22, 2023 14:29:13 GMT -7
I just notice that on my MT-10, it has tons of power, but it does like the clutch slipped a bit at launch and under 25mph... after that it has enough revs that it doesn't feel like its lugging the motor... Many of my Ducati's were like that... pulled like a freight train, but hating being under 3500rpm... I posted in another thread about it, but when the MT10 is below 6000rpms in first/second, you're only getting at MOST 34% throttle, when it's wide open. The electronic throttle valve mapping stock is *extremely* limited at low RPM. Probably a mix of safety, noise, and emissions restrictions. Most flashes remove these limitations an map the throttle 1:1 to the throttle position regardless of rpm.
squiresca
Post by squiresca on Oct 22, 2023 14:59:04 GMT -7
I just notice that on my MT-10, it has tons of power, but it does like the clutch slipped a bit at launch and under 25mph... after that it has enough revs that it doesn't feel like its lugging the motor... Many of my Ducati's were like that... pulled like a freight train, but hating being under 3500rpm... I posted in another thread about it, but when the MT10 is below 6000rpms in first/second, you're only getting at MOST 34% throttle, when it's wide open. The electronic throttle valve mapping stock is *extremely* limited at low RPM. Probably a mix of safety, noise, and emissions restrictions. Most flashes remove these limitations an map the throttle 1:1 to the throttle position regardless of rpm. Pretty sure that my flash and tune by Moore Mafia did all that stuff. I do that all myself on my Triumphs, with TuneECU... But I don't have Woolich so I take it to Chris and let him work his manage...
