shanasman450
AIS/PAIR
Sept 2, 2023 0:26:10 GMT -7
via mobile
Post by shanasman450 on Sept 2, 2023 0:26:10 GMT -7
I'm having some trouble nailing down an answer to these two questions and I'm hoping someone here knows the answers.
First, is the AIS system naturally open or closed on the 2021 and older models? I've found exactly one user claiming it's naturally closed, but I like to have at least two or three sources claiming the same thing before I consider something confirmed.
Second, does anyone know the outer diameter of the vent in the airbox? That's something I can check for myself when I get down under the tank, but having that info beforehand would mean I could skip the run into town between the disassembly and reassembly of the bike.
Thanks in advance.
Post by mt10orc on Sept 3, 2023 7:45:52 GMT -7
Closed. I asked the same question when I did my flash on my 2020. No need for block off plates.
Sorry not sure about your second question.
shanasman450
Post by shanasman450 on Sept 4, 2023 1:16:14 GMT -7
Closed. I asked the same question when I did my flash on my 2020. No need for block off plates. Sorry not sure about your second question. Sweet, I appreciate the response. The second question doesn't need answered if the stock system is staying in.
