tinpusher50
Post by tinpusher50 on Aug 17, 2023 17:23:27 GMT -7
I have a 2023 MT-10 with a slip-on Arrow titanium exhaust. I am considering the Arrow titanium link pipe, looking for louder sound. I don’t plan to flash ECU as I feel the bike has plenty of power for street use, I really just want it to be louder. Already been down once due to an inattentive driver, not looking to repeat that experience. If I plug in O2 sensors and get a servo buddy, but don’t flash ECU, will I keep cruise control function?
Post by mt10orc on Aug 17, 2023 18:16:56 GMT -7
I’m sure your cruise control should function with the mods you are suggesting . Although with a decat delete I would probably flash the bike. Do your research on the mid pipe/decat for the new gen bike and the mid pipe you are buying to see if they do their homework when they manufacturer the pipe to be compatible with the stock fueling map.
2wheeledprivilege
Post by 2wheeledprivilege on Aug 17, 2023 18:21:03 GMT -7
+1 for the ECU flash, bike will likely run way to lean due to increased airflow.
blueribbonrm
Post by blueribbonrm on Aug 17, 2023 18:58:09 GMT -7
I have heard the servo buddy doesn't always work right, just remove the cables and leave the motor plugged in under the seat. Even with the flash, that must remain plugged in, the PAIR valves must be plugged in, and the o2 sensors must be plugged in to keep everything working on a 2023.
Post by mt10orc on Aug 17, 2023 21:05:34 GMT -7
I have heard the servo buddy doesn't always work right, just remove the cables and leave the motor plugged in under the seat. Even with the flash, that must remain plugged in, the PAIR valves must be plugged in, and the o2 sensors must be plugged in to keep everything working on a 2023. Not sure about the ‘23. On my 2020, I undid the cables and left the servo motor plugged in. My O2 sensors were deleted. Edit: So looks like new gen needs the exup and o2 sensors connected for cruise control. Will also need block off plates as well as the AIS isn’t in closed position like previous gen when flashed. Added a link write up by VCyclenut. Guessing you found it as well.
tinpusher50
Post by tinpusher50 on Aug 19, 2023 12:09:09 GMT -7
I have heard the servo buddy doesn't always work right, just remove the cables and leave the motor plugged in under the seat. Even with the flash, that must remain plugged in, the PAIR valves must be plugged in, and the o2 sensors must be plugged in to keep everything working on a 2023. Could you elaborate on the PAIR valves situation, I have not come across that term yet anywhere. Does it have anything to do with AIS block off plate, or is that a separate thing?
terrys
Post by terrys on Aug 19, 2023 17:50:40 GMT -7
PAIR and AIS are the same thing; an air injection system at the header pipes to reduce emissions.
blueribbonrm
Post by blueribbonrm on Aug 19, 2023 20:12:42 GMT -7
Instead of block off plates I just shoved a marble in the hose that goes from the valves to the air box, left valves plugged in and have 0 issues.
Post by willl84 on Aug 21, 2023 8:24:23 GMT -7
Like others have said, the second gen bikes (22+) need the O2 sensors and EXUP motor still plugged in even with a flash.
tinpusher50
Post by tinpusher50 on Aug 22, 2023 17:09:47 GMT -7
Thanks to everyone who took time to answer, it’s all very helpful!
goliath337
Post by goliath337 on Aug 26, 2023 16:29:08 GMT -7
Install link pipe (Akra in my case) Leave O2 in place Leave servo motor in place Leave AIS system, use the marble trick Upgrade filter Flash ECU to avoid lean conditions Enjoy new found power curve
sammy26
Post by sammy26 on Apr 20, 2024 16:37:37 GMT -7
Quote:
Install link pipe (Akra in my case) Leave O2 in place Leave servo motor in place Leave AIS system, use the marble trick Upgrade filter Flash ECU to avoid lean conditions Enjoy new found power curve…
So do ALL ⬆️ this AND retain cruise control on 2022+ Bikes?
Thanks!
