mt10spswden
Post by mt10spswden on Jun 19, 2023 13:46:54 GMT -7
have a problem that has arisen with my mt10 sp, if I shift up with the clutch, they work 1- n -2 but to 3, it feels like they are a block in the gearbox and its completely impossible to get into a higher gear and its the same all the way up to 6th, the strange thing is that it works perfectly with quickshift through all gears, downshift works FINE with clutch though. any1 had the same problem?
Post by RedAndBlack on Jun 19, 2023 14:53:08 GMT -7
Welcome to the forum!
I gotta admit, it is weird that the problem doesn't exist with the quickshifter. But i do know There seems to be a reoccurring issue that has affected a lot of riders including myself. Check the shift linkage and try to adjust it into a different configuration. I had this issue, but I think it was 2nd gear and that's what helped resolve it.
Post by mindcrime79 on Jun 22, 2023 7:51:57 GMT -7
Check the ball joints on the shift rod. One of mine seized up which prevented shifting.
