navuk
Post by navuk on Jun 14, 2023 16:33:47 GMT -7
replaced the battery on my MT/FZ10 today and for few seconds I connected the terminals wrong way around. It blew the 50amp main fuse and the 7.5amp Throttle fuse which I have replaced now. I am now getting power, the fuel pump is priming but the bike won't turn over. There is no sound from the starter motor and neither the tacho lights are going dim as they do when you crank the engine.
Any advice will be appreciated
Post by RedAndBlack on Jun 14, 2023 17:15:39 GMT -7
Welcome to the forum!
You're definitely not the first this has happened to. There's definitely other posts in this section that may help you out and give you some ideas.
You may need to completely replace the battery as well.
navuk
Post by navuk on Jun 14, 2023 17:40:47 GMT -7
Welcome to the forum! You're definitely not the first this has happened to. There's definitely other posts in this section that may help you out and give you some ideas. You may need to completely replace the battery as well. I have read from other posts that they had to replace both of the fuses and the problem got resolved which I have done. Just cannot seem to figure out what the problem is. I have checked all the other fuses and they all seem ok
Post by mt10orc on Jun 14, 2023 20:25:34 GMT -7
May be the starter is the problem now. May want to check it out. May also want to ensure your kill sensor for the kick stand isn’t causing the issue as well. Kind of sounds like your bike thinks it’s in gear with kickstand extended. I would maybe also disco the battery again and reconnect after 10 minutes or so.
navuk
Post by navuk on Jun 15, 2023 4:17:35 GMT -7
May be the starter is the problem now. May want to check it out. May also want to ensure your kill sensor for the kick stand isn’t causing the issue as well. Kind of sounds like your bike thinks it’s in gear with kickstand extended. I would maybe also disco the battery again and reconnect after 10 minutes or so. Thanks for the advice, I'll see if I can bump start it, if it brings it back to life then I know it's the starter motor
navuk
Post by navuk on Jun 15, 2023 8:40:33 GMT -7
Managed to find the problem. It's the starter relay/solenoid under the seat which got burned. I bridged the connectors and it started cranking over. Thanks to everyone who tried to help out
Post by RedAndBlack on Jun 15, 2023 20:43:21 GMT -7
kaos90
Post by kaos90 on Jun 18, 2023 9:27:14 GMT -7
The reversed battery issue seems to come up pretty frequently.
Tech tip for everyone: take pictures of whatever you are working on beforehand. Saves you a lot of hassle!
As a master automotive technician for over 50 years, making a sketch or taking pictures is the way to happiness and enlightenment!
Post by mt10orc on Jun 18, 2023 16:02:33 GMT -7
The reversed battery issue seems to come up pretty frequently. Tech tip for everyone: take pictures of whatever you are working on beforehand. Saves you a lot of hassle! As a master automotive technician for over 50 years, making a sketch or taking pictures is the way to happiness and enlightenment! A good habit to have as it is part of my repertoire.
