Post by willl84 on Apr 24, 2023 15:27:18 GMT -7
maxxj
Post by maxxj on Apr 27, 2023 6:07:22 GMT -7
I have not, but the swingarm part numbers for the 2019 10 and r1 are different. The axle numbers are the same though. As long as the axle block channels and axle are the same it should be fine I think.
Post by willl84 on Apr 27, 2023 6:49:08 GMT -7
Someone on one of the FB groups said they installed them and they fit just fine. They also said they're not that easy to use if you're using them a lot and the Lightech ones are easier to use. I had the old Gilles units on my TLR and LOVED them. They looked and worked great. I want these to use the lifter hooks you can get with them but I think Lighttech has those as well.
