cowthulhu
Post by cowthulhu on Mar 19, 2023 21:12:53 GMT -7
Anyone know what size the copper washer is for the water drain bolt? Just bought an MT10 used and want to replace the coolant for peace of mind. I found the part on partzilla but would rather get some cheaper at the shop. Thank you. Copper Washer on Partzilla
Post by parthz8 on Mar 20, 2023 14:19:14 GMT -7
Recently I serviced my R1M and last week MT10 (Coolant drain, flush and re-fill) and installed new copper washer. Size: M6x12x1 If you can get OD 10mm, better but 12mm also works.
cowthulhu
Post by cowthulhu on Mar 20, 2023 20:16:23 GMT -7
Recently I serviced my R1M and last week MT10 (Coolant drain, flush and re-fill) and installed new copper washer. Size: M6x12x1 If you can get OD 10mm, better but 12mm also works. Awesome, thank you so much!
