jbnnc
Post by jbnnc on Dec 3, 2022 11:35:58 GMT -7
Hi All,
I ordered a link pipe and ECU tune and need to remove my ECU. The 22 is different from previous years and I'm looking for instructions for removal. I've only found the Yamaha manual option for $100 and they print it on demand. I appreciate alternative options if you are aware. I've searched this forum and on line in general and have fond great instructions for previous years, nothing for 22.
Thank you, JB
kyle
Post by kyle on Dec 3, 2022 16:53:07 GMT -7
blueribbonrm
Post by blueribbonrm on Dec 3, 2022 21:30:07 GMT -7
I recall seeing a YouTube video or two of the removal process, believe one was from a user named MT Hatter
Post by willl84 on Dec 4, 2022 4:08:30 GMT -7
I recall seeing a YouTube video or two of the removal process, believe one was from a user named MT Hatter Yep: Take it with a grain of salt, he spent money on a Toce after all 🤣
jbnnc
Post by jbnnc on Dec 4, 2022 14:45:25 GMT -7
Thanks for the responses and links, I had found that video, it does not include the removal and he did not post one for the removal. I've searched for a minute and can't locate any 2022 ecu removal videos. I will order the paper manual this evening and be patient, hard to do in the age of Amazon.
jmm0122
Post by jmm0122 on Dec 14, 2022 6:27:08 GMT -7
imfa
Post by imfa on Apr 22, 2023 12:13:18 GMT -7
Is the ECU loose inside / under the plastic tray or is it fixed in any way?
squiresca
Post by squiresca on Apr 24, 2023 13:03:42 GMT -7
Made a video of it recently
turdferguson
Post by turdferguson on Apr 30, 2023 13:23:31 GMT -7
Made a video of it recently Any Updates on the MT-10 flash and the issue you had? My new '23 MT-10 is coming this week and I am planning to send the ECM to David at Vcyclenut for a flash. David did my '22 Tracer 9GT ECM flash in January and after re-installing the ECM, then clearing the codes with a cheap $13 amazon scanner like yours she was fine and has been now for over 3000 miles more. Are there more reports of these issues after re-install of a flashed ECM??
squiresca
Post by squiresca on Apr 30, 2023 13:48:37 GMT -7
I used my bluetooth OBD scanner and my phone with the Torque Pro app. I was able to clear all the codes and no issues since.
