larsony99
Post by larsony99 on Nov 4, 2022 7:23:19 GMT -7
This is bizarre. I was installing my fender eliminator last night, and the OEM turn signals have these like "tubes" as a part of the wiring harness. Please see the image below. What in the world is this lol? I didn't want to take it apart. The only thing I could think of was that they like soldered resistors in there or something?
Post by mt10orc on Nov 4, 2022 8:20:18 GMT -7
This is bizarre. I was installing my fender eliminator last night, and the OEM turn signals have these like "tubes" as a part of the wiring harness. Please see the image below. What in the world is this lol? I didn't want to take it apart. The only thing I could think of was that they like soldered resistors in there or something? I have those as well. No idea what they are for.
Post by willl84 on Nov 4, 2022 10:12:03 GMT -7
I believe they're the resistors to keep from hyperflashing with the LED's
larsony99
Post by larsony99 on Nov 4, 2022 10:13:36 GMT -7
I believe they're the resistors to keep from hyperflashing with the LED's It's not like Yamaha could just put in an alternate flasher module designed for LEDs lol. Euro bikes don't have them. They aren't even shown on the parts diagrams (the tubes).
Post by willl84 on Nov 4, 2022 10:16:18 GMT -7
I believe they're the resistors to keep from hyperflashing with the LED's It's not like Yamaha could just put in an alternate flasher module designed for LEDs lol. Euro bikes don't have them. They aren't even shown on the parts diagrams (the tubes). I wonder if the Euro bikes hyperflash when a signal goes out like here in the US? Might be part of the reason for them. My 2019 has them too. Might also be part of the reason why the OEM signals are so fucking expensive.
larsony99
Post by larsony99 on Nov 4, 2022 10:17:26 GMT -7
It's not like Yamaha could just put in an alternate flasher module designed for LEDs lol. Euro bikes don't have them. They aren't even shown on the parts diagrams (the tubes). I wonder if the Euro bikes hyperflash when a signal goes out like here in the US? Might be part of the reason for them. My 2019 has them too. Might also be part of the reason why the OEM signals are so fucking expensive. Oh, you know what? I think there's some law requiring hypeeflash when your lights go out here. That could be it, good point.
Post by parthz8 on Nov 4, 2022 13:57:35 GMT -7
Yes tube contains Resistor for each Turn Signal (I have those on R1M too..). They are required as flash controller and current limiter to protect LED. Not sure why European models don't have them (may be inbuilt in SMDs? Highly doubtful..) They are in tube for heat dissipation. Resistors are shown in Signaling Electrical diagram.
Post by willl84 on Nov 7, 2022 5:01:08 GMT -7
Yes tube contains Resistor for each Turn Signal (I have those on R1M too..). They are required as flash controller and current limiter to protect LED. Not sure why European models don't have them (may be inbuilt in SMDs? Highly doubtful..) They are in tube for heat dissipation. Resistors are shown in Signaling Electrical diagram. 99% sure they're just for flash speed control and nothing to do with current limiting for the LEDs. The current limiting will be on-board the PCB inside with the LEDs themselves. Those resistors are way too big for current limiting on 3 LEDs lol. Otherwise the Euro bike would have the resistor tubes too.
