platoon03
Post by platoon03 on Oct 23, 2022 13:10:55 GMT -7
Hey all, I‘m a new owner of 2020 MT-10 (5000km) and have one question considering a clutch lever run. I‘ve noticed some kind of a short resistance at the very beginning (1-2mm) when clutching in. It „sticks“ for a moment somehow. It always happen when upschifting while revving (4rpm and above). When coasting (3-4 rpm) or engine runs idle the lever goes smoothly. Its not a big deal but it is noticeable. It is my 4th Yamaha (but 1st MT) and i didn‘t notice this kind of thing on my other bikes. Perhaps it is a MT feature, i don‘t know)) The clutch lever was not an original one when i bought the bike and had a vertical play in pivot area, so i bought a new lever with 0 play but the „problem“ stayed. That is the only issue considering a work of the clutch. Shifting goes well)
Any suggestions?
P.S. When doing a year inspection a month ago they didn‘t find anything suspicious 🤷♂️
Thank you!
Alex
Post by willl84 on Oct 24, 2022 5:48:09 GMT -7
The only issue I have with mine is that the clutch is SUPER grabby when the engine is cold. I've stalled numerous times due to this and it's embarrassing lol.
Post by mt10orc on Oct 24, 2022 17:18:10 GMT -7
Have the same year and not experienced that. Have you lubed the cable and ensure u have grease at the pivot pin?
platoon03
Post by platoon03 on Oct 24, 2022 21:35:56 GMT -7
Have the same year and not experienced that. Have you lubed the cable and ensure u have grease at the pivot pin? Hi! No, i haven‘t lubed the cable yet. Just thought: 2 years old bike with 5000km, the cable must be virgin)) Another thing that stoped me: when engine is off or runs idle, the lever goes very smooth and i don‘t feel that resistance anymore. So it doesn‘t sound like a cable problem or am i wrong? And yes, the pivot has enough grease, i made sure of that when i changed the lever a week ago. Thank you!
Post by willl84 on Oct 25, 2022 6:21:38 GMT -7
Have the same year and not experienced that. Have you lubed the cable and ensure u have grease at the pivot pin? It's not the lever or cable, it's gotta be something internal. It only does it when the bike it cold, like when I first leave my driveway in the am or work in the pm. A mile down the road it's fine and never does it again.
Post by mt10orc on Oct 25, 2022 11:22:36 GMT -7
Wonder if there is a internal clutch adjustment like my FXST had? Sorry working so no access to shop manual.
Post by willl84 on Oct 25, 2022 11:40:51 GMT -7
Wonder if there is a internal clutch adjustment like my FXST had? Sorry working so no access to shop manual. Nothing at all internal. The lever on the cover turns a rod which pushed on the clutch to open it.
