rabbix
Post by rabbix on Oct 16, 2022 14:05:34 GMT -7
I noticed some oil on the garage floor yesterday, so I took a close look at the bike and found the oil was leaking from both the gasket of the oil pan, the drain plug, and one bolt of the clutch cover. This bike was bought on Aug 20 and only have less than 800KM mileage. I'm really disappointed with Yamaha's quality now.
jmm0122
Post by jmm0122 on Oct 16, 2022 16:39:00 GMT -7
I noticed some oil on the garage floor yesterday, so I took a close look at the bike and found the oil was leaking from both the gasket of the oil pan, the drain plug, and one bolt of the clutch cover. This bike was bought on Aug 20 and only have less than 800KM mileage. I'm really disappointed with Yamaha's quality now. Good thing it's new and under warranty. That's why one is offered. Sadly no companies products are perfect.
Post by hooli on Oct 16, 2022 16:59:47 GMT -7
No bike manufacturer is flawless...whatever brand you get, you're going to have some sort of issue (and that goes for just about everything these days). Be grateful that it's a relatively small matter that's covered under warranty.
kyle
Post by kyle on Oct 17, 2022 15:19:51 GMT -7
Oh wow - very interesting! I wonder if the dealer overfilled the engine oil? I'm pretty sure mine is ok, but I will definitely double-check. Keep us updated on the warranty claim - I hope the process is as painless as possible for you. EDIT: Thank you will for pointing out that dealers don't fill the oil
Post by willl84 on Oct 18, 2022 4:24:38 GMT -7
Oh wow - very interesting! I wonder if the dealer overfilled the engine oil? I'm pretty sure mine is ok, but I will definitely double-check. Keep us updated on the warranty claim - I hope the process is as painless as possible for you. Dealers don't fill the oil during PDI. It comes filled. They just check it.
rabbix
Post by rabbix on Oct 18, 2022 11:54:13 GMT -7
Will drop off the bike at dealer this afternoon. BTW, my friend’s 2022 MT10 SP is leaking too.
Post by evitzee on Oct 19, 2022 19:02:08 GMT -7
My 2017 FZ-10 bought in Nov 2016 is still tight after almost six years, no leaks or seeps at all. There have been a few instances of leaking oil pans, but they'll get fixed under warranty. No product is perfect.
rabbix
Post by rabbix on Oct 21, 2022 9:15:29 GMT -7
The dealer believed the leakage was caused by overfill. They reduced the oil to normal level. No leakage found so far.
