adrenaline99
Post by adrenaline99 on Oct 4, 2022 18:27:22 GMT -7
Hello, I just bought a 2022 MT-10 SP and still getting used to the electronics and user input, when I turn the key to the on position, the warning sign comes on (triangle with exclamation inside). And it stays on until I start the engine, is this intended or do I need to get it looked at?
Post by mt10orc on Oct 4, 2022 18:32:54 GMT -7
Hello, I just bought a 2022 MT-10 SP and still getting used to the electronics and user input, when I turn the key to the on position, the warning sign comes on (triangle with exclamation inside). And it stays on until I start the engine, is this intended or do I need to get it looked at? Yes that is normal. It’s probably like most vehicles with advanced electronics that is a pre check that the system is functioning and goes off upon start. This is only a best guess as not totally sure. I know on my 2020 my ABS stays on until started.
adrenaline99
Post by adrenaline99 on Oct 4, 2022 18:36:51 GMT -7
Hello, I just bought a 2022 MT-10 SP and still getting used to the electronics and user input, when I turn the key to the on position, the warning sign comes on (triangle with exclamation inside). And it stays on until I start the engine, is this intended or do I need to get it looked at? Yes that is normal. It’s probably like most vehicles with advanced electronics that is a pre check that the system is functioning and goes off upon start. This is only a best guess as not totally sure. I know on my 2020 my ABS stays on until started. Yeah my ABS stays on until started as well, along with oil pressure. But both of those I know are normal, it's just the warning light I am confused about.
Post by mt10orc on Oct 4, 2022 19:08:23 GMT -7
Let’s hope another 2022 owner chimes in.
Post by willl84 on Oct 5, 2022 6:17:04 GMT -7
Hello, I just bought a 2022 MT-10 SP and still getting used to the electronics and user input, when I turn the key to the on position, the warning sign comes on (triangle with exclamation inside). And it stays on until I start the engine, is this intended or do I need to get it looked at? Yes that is normal. It’s probably like most vehicles with advanced electronics that is a pre check that the system is functioning and goes off upon start. This is only a best guess as not totally sure. I know on my 2020 my ABS stays on until started. The ABS stays on until you start moving. OP: Yes, it's normal. Things like a CEL and oil pressure lights wills tay on until the engine is running. Once it's started the system gets readings from all the sensors and once everything is OK the lights go out. Also your ABS light might stay on but once you start rolling it'll go out. This is for the same reason.
Post by parthz8 on Oct 6, 2022 13:42:09 GMT -7
As per MT 10 SP Owners Manual, Aux system warning light (triangle with !) is comes ON with vehicle ON, but should turn OFF in few seconds if no engine issues are present. ABS goes OFF after 5km/h or higher, if ABS is working properly. Guess its good time to go through the manual provided with Motorcycle (Its really helpful)
semprenissart
Post by semprenissart on Oct 7, 2022 18:40:46 GMT -7
I don't want to create a new thread just for that so I'll ask it here.
Anyone knows where is the OBD port on the 2022? I can't find it anywhere online and I don't know which one it is under the seat. There's a red cable/port near the fuel tank on the left side, I don't know if it's this one but if it is, then the port is different than the previous gen.
Does anyone know?
Post by parthz8 on Oct 8, 2022 15:16:05 GMT -7
I don't want to create a new thread just for that so I'll ask it here. Anyone knows where is the OBD port on the 2022? I can't find it anywhere online and I don't know which one it is under the seat. There's a red cable/port near the fuel tank on the left side, I don't know if it's this one but if it is, then the port is different than the previous gen. Does anyone know? Hi semprenissart Yes, port on MT10 & MT10 SP 2022 onward is different, check Consumer Information page in User manual section 11-3. Its newer (Euro V) red 6 pin OBD2 bike plug. It connects to red cable/port near the fuel tank on the left side (near to battery). Now ECU is below IMU underneath pillion seat.
semprenissart
Post by semprenissart on Oct 8, 2022 19:58:21 GMT -7
Awesome.
Thanks a lot man!
