Post by mindcrime79 on Sept 22, 2022 4:47:02 GMT -7
Does anyone know if the ball joint is supposed to be loose and fluid? The top one on my shifter is tight and the bike no longer shifts normally. Lubrication does nothing...I may have over tightened it at some point...
Post by parthz8 on Sept 24, 2022 4:41:27 GMT -7
Hello, please see below OEM set-up on MT-10 (2021). Ball joint (i verified both top and bottom) came from factory loose and fluid. I grease it with Lithium-Soap based lube. No issue with shift and its normal (even after completely removing it past and re-installing it back as per factory specs). Hope this helps...
Post by mindcrime79 on Sept 24, 2022 5:04:44 GMT -7
Thank you. Appreciate it. Happen to know if the top and bottom joint are identical? I'll have to order a new one. Not sure how it got messed up.
Post by parthz8 on Sept 24, 2022 6:19:26 GMT -7
Thank you. Appreciate it. Happen to know if the top and bottom joint are identical? I'll have to order a new one. Not sure how it got messed up. you are welcome Joint Rod 2 (5LV-18117-00-00) is bottom and Joint Rod 1 (5LV-18116-00-00) is upper as per below parts list. They both looks same (just inverted), but i will verify on bike itself today late evening.
Post by willl84 on Sept 25, 2022 3:30:44 GMT -7
Thank you. Appreciate it. Happen to know if the top and bottom joint are identical? I'll have to order a new one. Not sure how it got messed up. you are welcome Joint Rod 2 (5LV-18117-00-00) is bottom and Joint Rod 1 (5LV-18116-00-00) is upper as per below parts list. They both looks same (just inverted), but i will verify on bike itself today late evening. They're not the same. One is LH thread and one is RH thread. That's why both the parts and their accompanying nuts have different part numbers. This is what makes the shift lever height adjustment work properly.
Post by mindcrime79 on Sept 25, 2022 5:08:00 GMT -7
Alright thank you 😑... Will order correct piece.
