nofi
Post by nofi on Jul 30, 2022 10:15:53 GMT -7
Manual states 10w-40 or 15w-50. Which should I use. I have 100 miles on my MT10. I have a supply of Mobil 1 10w-40, Motul 10w-40 full synthetic and Motul 300V 10w-40. The Yamaha dealer said I should use 15w-50 Yamalube. I would like a second opinion, please. I am a newbie to this forum and have recently upgraded from a 2019 MT-09 which is for sale.
Post by Deleted on Jul 30, 2022 11:42:57 GMT -7
Either is just fine. If you live in a cooler climate use the 10w40. Warmer 15w50.
I've always used 10w40 Mobil full synthetic
nofi
Post by nofi on Jul 30, 2022 11:45:44 GMT -7
Who makes Yamalube?
amateur
Post by amateur on Jul 30, 2022 12:32:18 GMT -7
My understanding is Yamlube is sourced from several different suppliers depending on both the market it is being supplied to and current oil refinery issues and supplies. When I was employed by Yamaha NZ, 15 years ago to be fair, our bulk oil, 44 gallon drums of marine & MC oil, came from Singapore and the prepackaged retail packs came via YMUS. Sometimes market influences saw us bringing in retail packs from YME (Europe). That is one of the reasons punters claim, “it’s repackaged Motul” etc. A particular batch of Yamalube product will have been manufactured by the same refinery that also produces oil for other brands.
Post by RedAndBlack on Jul 30, 2022 14:17:51 GMT -7
Welcome to the forum!!! I combined your threads since they were basically the same topic.
Don't make it out harder than it needs to be. The manual actually covers the oil thing pretty good, it's not any harder than that. If you're not in any climate extremes, it's doesn't matter much between the 10w vs 15w. The manual provides that graph explaining the temperature coverages.
As for oil, any fully synthetic that meets the JASO recommendations is fine. In my opinion, Motul is race oil and overkill for most people considering the cost. But if you have some left, it's probably better to use them sitting on a shelf somewhere getting old.
mt1021
Post by mt1021 on Jul 30, 2022 20:05:05 GMT -7
Me personally, on a brand new bike, I would stick to the manufactured recommended oil and brand until the bike is properly broken in and has a couple thousand miles under it. For warranty purpose only! Or keep receipts and create a personal maintenance log with paper trail. Not to say there is anything wrong with the other oils, just don’t like nor want to deal with corporates on non senses if anything happens.
iwasatoad
Post by iwasatoad on Jul 31, 2022 4:18:33 GMT -7
I have ran both 10w-40 and 15-50 both Ams oil. found no temp change. and had both sent off for testing to see ware rate 0 problems wisconsin weather from 35f -106 on trips
Post by parthz8 on Jul 31, 2022 5:24:00 GMT -7
Manual states 10w-40 or 15w-50. Which should I use. I have 100 miles on my MT10. I have a supply of Mobil 1 10w-40, Motul 10w-40 full synthetic and Motul 300V 10w-40. The Yamaha dealer said I should use 15w-50 Yamalube. I would like a second opinion, please. I am a newbie to this forum and have recently upgraded from a 2019 MT-09 which is for sale. Nofi, i remember researching (rather spending too much time on this when my 1st service was almost due for my 2021 MT-10) on engine Oil. Go with Yamalube Perfomance Full-Syn 15W-50 (i am using this also on my R1M). Now they have newer packaging with blue sticker... Note: i live in region where max ambient temperature goes 50deg Celsius in summer and 14deg Celsius in Winter. Also change Drain bolt and washer to avoid leakage, if still using OEM (not required but recommended).
Post by mt10orc on Jul 31, 2022 19:04:58 GMT -7
Yamalube, filter, and crush washer for both the R1 and MT. I reuse the bolt. I live in the Pacific NW.
Post by willl84 on Aug 1, 2022 7:34:40 GMT -7
Manual states 10w-40 or 15w-50. Which should I use. I have 100 miles on my MT10. I have a supply of Mobil 1 10w-40, Motul 10w-40 full synthetic and Motul 300V 10w-40. The Yamaha dealer said I should use 15w-50 Yamalube. I would like a second opinion, please. I am a newbie to this forum and have recently upgraded from a 2019 MT-09 which is for sale. Nofi, i remember researching (rather spending too much time on this when my 1st service was almost due for my 2021 MT-10) on engine Oil. Go with Yamalube Perfomance Full-Syn 15W-50 (i am using this also on my R1M). Now they have newer packaging with blue sticker... Note: i live in region where max ambient temperature goes 50deg Celsius in summer and 14deg Celsius in Winter. Also change Drain bolt and washer to avoid leakage, if still using OEM (not required but recommended). You never need to change the bolt but yes always the crush washer
Post by Deleted on Aug 1, 2022 9:20:41 GMT -7
Odd my bike came with a solid thick washer from day 1 and I've just been reusing it over and over.
Has Yamaha moved over to crush washers on the newer models?
Post by willl84 on Aug 1, 2022 9:32:05 GMT -7
Odd my bike came with a solid thick washer from day 1 and I've just been reusing it over and over. Has Yamaha moved over to crush washers on the newer models? It's a solid washer but it's still considered a crush washer. I know what you mean though - my TL1000R had one that would actually "crush" when tightened.
minlak
Post by minlak on Aug 1, 2022 14:25:13 GMT -7
I find this interesting in the manual - Apparently you only change the filter every second oil change? To me its like you pooped your pants then had a shower and put the same pants back on
Post by Deleted on Aug 2, 2022 6:21:29 GMT -7
Normal oil changes I change the filter every time.
But when I do track days I will change my oil every time and sometimes I dont change the filter because theres literally only a few hundred miles between changes.
Post by willl84 on Aug 2, 2022 6:41:21 GMT -7
I find this interesting in the manual - Apparently you only change the filter every second oil change? To me its like you pooped your pants then had a shower and put the same pants back on Yea I do the filter every single time. It's cheap insurance.
Post by parthz8 on Aug 2, 2022 7:02:11 GMT -7
Changing Engine Oil Filter cartridge everytime you replace Engine Oil makes sense and very easy (accessible) on MT-10s. Its pain in the a** on R1 & R1Ms where you have to open complete cowlings, sounds lazy but true to follow service manual
Post by parthz8 on Aug 2, 2022 7:17:11 GMT -7
BTW, found another thread on this Topic with some useful information and links.... fz10.org/thread/1833/type-oilI started using Motion pro Oil Filter Magnet with engine Oil Cartridges after recommendation on above thread. May be something useful (Make sure to get proper size matching filter)
jans4
Post by jans4 on Dec 30, 2022 1:08:49 GMT -7
MODERATOR NOTE: USER BANNED FOR SPAM
2wheeledprivilege
Post by 2wheeledprivilege on Jun 20, 2023 18:28:30 GMT -7
Which weight oil, would you all suggest? Manual says 10W/40 or 15W/50, it will be Yamalube regardless of viscosity. Bike has a bit under 600 miles and ambient temperatures have been in the mid 90s (F) during the day. I am leaning to the slightly heavier (15W/50) and a full synthetic.
Thank you all for you thoughts/input
Post by Deleted on Jun 21, 2023 6:11:52 GMT -7
I have always used 10w/40 and I live in Texas where it gets to 105+ on a regular basis (although I try not to ride in that heat) and do multiple track days per year. Never had any issues.
