victortanasa
Remap
Jul 28, 2022 7:27:24 GMT -7
Post by victortanasa on Jul 28, 2022 7:27:24 GMT -7
Hi, I have a '17 model, with an Akra slip on (cat still on, don't want to get rid of it).
I'm thinking of doing a tune, the main reason not being more HP, but better on / off throttle feel and getting rid of any flat spots.
1. What should I look out for, what parameters can I tell the tuner to change?
2. Should I remove the restrictions on wide open throttle?
3. Does the mpg go down after a tune? I could do with it being slightly worse, but not something like 15-20%.
I don't want a blown motor or 200 hp, as the bike is fast enough, just a better overall feel.
Cheers!
weehe
Remap
Jul 28, 2022 8:04:09 GMT -7
via mobile
mt10orc likes this
Post by weehe on Jul 28, 2022 8:04:09 GMT -7
If you are in the states, send it to 2WDW. Not going to blow your motor. I'm getting 32mpg spirited riding, 36mpg spirited highway driving.
victortanasa
Remap
Jul 28, 2022 8:19:33 GMT -7
via mobile
Post by victortanasa on Jul 28, 2022 8:19:33 GMT -7
Thanks for the suggestion. Unfortunately, I'm in Europe.
weehe
Remap
Jul 28, 2022 16:24:35 GMT -7
via mobile
parthz8 likes this
Post by weehe on Jul 28, 2022 16:24:35 GMT -7
Should be able to use Woolich then.
Remap
Jul 30, 2022 8:03:29 GMT -7
Post by mt10orc on Jul 30, 2022 8:03:29 GMT -7
Hi, I have a '17 model, with an Akra slip on (cat still on, don't want to get rid of it). I'm thinking of doing a tune, the main reason not being more HP, but better on / off throttle feel and getting rid of any flat spots. 1. What should I look out for, what parameters can I tell the tuner to change? 2. Should I remove the restrictions on wide open throttle? 3. Does the mpg go down after a tune? I could do with it being slightly worse, but not something like 15-20%. I don't want a blown motor or 200 hp, as the bike is fast enough, just a better overall feel. Cheers! IMO it will be the best thing you could do to the bike. Doing with cat tune isn’t going to change the MPG much if any but will smooth out you throttle to not be so jerky. You may gain a few horse but nothing like the decat tune. Just advise the tuner you use, the exact setup on your bike (Akra) and they will go from there. If Woolich is anything like 2WDW they will set it up correctly. Give them a call and chat with them about it to set ur mind at ease.
Remap
Jul 30, 2022 8:20:07 GMT -7
Post by parthz8 on Jul 30, 2022 8:20:07 GMT -7
Thanks for the suggestion. Unfortunately, I'm in Europe. I have done Woolich Tuning on my Yamaha R1M (outside USA), (earlier it was running too lean - tuned Power mode 1). They will send logging device (LogBox-V3 or similar for MT-10) when you purchase proper kit with Zeitronix ZT-3. Some modification on link pipe or exhaust pipe will be required to installed Bosch O2 sensor from Zeitronix to communicate with Woolich LogBox. With Bin Key, you can send them log file or autotune the ECU. If you are not looking for 200HP or blasting your motor, dyno run is also not required. LogBox record real time data while you are riding.
victortanasa
Post by victortanasa on Aug 1, 2022 3:19:31 GMT -7
Thanks for the tips!
