Post by Deleted on Jul 22, 2022 11:53:26 GMT -7
jlapaglia
Post by jlapaglia on Jul 22, 2022 12:18:50 GMT -7
I don’t have experience with either but it seems like the big advantage of the light tech ones is the “click” per adjustment to easily tell how many turns you’re doing. If the less expensive ones don’t have it I’m not sure how much they really make it easier. Do you only have to adjust one screw instead of two?
Post by willl84 on Jul 23, 2022 2:49:58 GMT -7
I'm looking at getting the Gilles ones soon. I've heard of people having problems with stripping out the axle side of the lightech ones. Also the drop down on the site you linked doesn't eve list the MT-10 at all
Post by hooli on Jul 27, 2022 9:39:46 GMT -7
I was running a set of Yoshimura axle blocks before I lucked out on a set of clean used Lightechs. Nowhere as fancy as the latter style but they look better than stock and are machined more accurately. You can also flip them if you want to run a longer wheelbase for track use.
Post by willl84 on Jul 27, 2022 11:14:44 GMT -7
I was running a set of Yoshimura axle blocks before I lucked out on a set of clean used Lightechs. Nowhere as fancy as the latter style but they look better than stock and are machined more accurately. You can also flip them if you want to run a longer wheelbase for track use. Those are purrrrty
Post by Deleted on Jul 27, 2022 12:24:47 GMT -7
I was running a set of Yoshimura axle blocks before I lucked out on a set of clean used Lightechs. Nowhere as fancy as the latter style but they look better than stock and are machined more accurately. You can also flip them if you want to run a longer wheelbase for track use. Me likey, I need to get some of those!!!
Post by mt10orc on Jul 27, 2022 16:07:30 GMT -7
Went with LightTech. Had money burning a hole in my pocket last winter and wanted some garage time.
Like the look of the Yoshi’s.
3genx
Post by 3genx on Aug 2, 2022 1:19:42 GMT -7
Post by willl84 on Aug 2, 2022 6:37:49 GMT -7
I prefer the look of adjusters that don’t hang out past the swingarm. Gilles tooling markets their TCA adjusters under their YZF-R1 lineup. I stripped the coating off to make them look more like the stock axel blocks. Great product and definitely something different. I’ve never seen them on another bike, not even on an R1. Maybe they’re just ugly and I’m the only one who can’t see that. Lol I wanted the Gilles ones (with the lifter hooks) but they only list them for the R1. I emailed them to ask if they'd fit the MT and was told no due to some minor difference I couldn't understand through translation lol. Glad to see they do indeed fit right on though! Also what rearsets are those?
Post by willl84 on Aug 2, 2022 6:38:24 GMT -7
I was running a set of Yoshimura axle blocks before I lucked out on a set of clean used Lightechs. Nowhere as fancy as the latter style but they look better than stock and are machined more accurately. You can also flip them if you want to run a longer wheelbase for track use. Me likey, I need to get some of those!!! I went looking - they're discontinued by Yosh and nobody has them in stock unfortunately.
Post by Deleted on Aug 2, 2022 6:43:49 GMT -7
I prefer the look of adjusters that don’t hang out past the swingarm. Gilles tooling markets their TCA adjusters under their YZF-R1 lineup. I stripped the coating off to make them look more like the stock axel blocks. Great product and definitely something different. I’ve never seen them on another bike, not even on an R1. Maybe they’re just ugly and I’m the only one who can’t see that. Lol These look nice and I found a US seller listing for $99. Does not say if they are sold individually or as a pair. How were yours sold?
Post by willl84 on Aug 2, 2022 7:00:27 GMT -7
Post by Deleted on Aug 2, 2022 7:16:42 GMT -7
Post by willl84 on Aug 2, 2022 7:20:35 GMT -7
Yea those are the other ones they offer lol
3genx
Post by 3genx on Aug 2, 2022 10:53:29 GMT -7
3genx
Post by 3genx on Aug 2, 2022 11:00:24 GMT -7
I wanted the Gilles ones (with the lifter hooks) but they only list them for the R1. I emailed them to ask if they'd fit the MT and was told no due to some minor difference I couldn't understand through translation lol. Glad to see they do indeed fit right on though! Also what rearsets are those? The rears sets are Evol Technology. hhrperformance.com/b-159180-evol-technology.html
Post by willl84 on Aug 2, 2022 11:22:52 GMT -7
Oh nice, thanks for the heads up
maxxj
Post by maxxj on Mar 13, 2023 2:50:09 GMT -7
Do you still need to block the chain or shove the wheel forward before tightening the axle nut with the lightech adjusters? Unless I'm looking at this wrong it looks like the axle hole is held stationary by the adjuster.
Post by parthz8 on Mar 13, 2023 8:28:44 GMT -7
With Lightech chain adjuster proper installed on both sided, before tightening the axle nut with stock axle it is recommended to wedge a wrench in between sprocket and chain just to force the axle into forward most position. Also if you are using a Pit Bull rear stand, tire wedge which fits into that is handy to do work without remove the wheel. I reached out to Lightech Italy and they instructed: For the tightening torque you must strictly follow the instruction that Lightech put inside the box. For MT 10, manufacturer specifies rear wheel axle nut Torque is 190 N-m but Lightech specify only 100 N-m!
Post by Deleted on Mar 13, 2023 9:05:10 GMT -7
