998noob
Post by 998noob on Jun 21, 2022 13:29:36 GMT -7
I'm wondering if 2022 QS/AB is backwards capable on FZ-10/MT-10 of previous years like the QS on 18-21 is for the 2017 FZ-10?
Post by mt10orc on Jun 22, 2022 16:34:16 GMT -7
That is a dam good question.
998noob
Post by 998noob on Jun 22, 2022 18:13:32 GMT -7
We need someone with resources to explore that. I don't have disposable funds to try it out myself.
Post by willl84 on Jun 23, 2022 5:41:56 GMT -7
I'm wondering if 2022 QS/AB is backwards capable on FZ-10/MT-10 of previous years like the QS on 18-21 is for the 2017 FZ-10? With my experience with my FTECU kit the ECU needs to be enabled for the blip function even if it came factory with the QS. Not sure if that applies to the OEM however. The other thing is the 22 will likely have a different harness as you'll need at least one extra wire for the blip function. On the FTECU kit this extra wire is inserted intot he ECU connector, replacing a pin that's currently there. My assumption is the flash makes the ECU know that that specific pin is the blip trigger. We'll have to wait until the 2022 OEM parts lookup comes out (I'm looking for the front reservoir anyways - not a huge fan of the Brembo one that came with my R1 m/c kit) and see what the cost of the unit itself is and see if it's even worth it. Retail for an OEM QS unit is ~$240. The FTECU kit can be had for around $400 if you look around but it also requires an ECU flash (free minus shipping if you already have your flashed with 2WDW).
998noob
Post by 998noob on Jun 23, 2022 6:25:18 GMT -7
I'm leaning towards OEM QS, but I was wondering about compatibility of 2022 unit before purchase.
Post by mt10orc on Jun 23, 2022 15:54:56 GMT -7
We need someone with resources to explore that. I don't have disposable funds to try it out myself. I have the funds but prefer to down shift manually. Already have the OE quick shifter and like it. Came stock on my 2020.
Post by willl84 on Jun 23, 2022 17:53:54 GMT -7
We need someone with resources to explore that. I don't have disposable funds to try it out myself. I have the funds but prefer to down shift manually. Already have the OE quick shifter and like it. Came stock on my 2020. I thought that way too until I test rode a ninja 1000 SX last year with a factory blipper and knew then I needed one lol. Here's a couple clips from today of my FTECU blipper in action:
998noob
Post by 998noob on Jun 23, 2022 19:56:45 GMT -7
Last year I tested an Aprilla Tuono 1100 Factory with QS/AB. It was sweet. I would love it on my FZ-10
Post by mt10orc on Jun 23, 2022 22:26:24 GMT -7
I have the funds but prefer to down shift manually. Already have the OE quick shifter and like it. Came stock on my 2020. I thought that way too until I test rode a ninja 1000 SX last year with a factory blipper and knew then I needed one lol. Here's a couple clips from today of my FTECU blipper in action: That is pretty badass. Ok Will you may have sold me on it. Guess I need to go test ride a bike with it. What camera are you using?
Post by willl84 on Jun 24, 2022 6:17:26 GMT -7
I thought that way too until I test rode a ninja 1000 SX last year with a factory blipper and knew then I needed one lol. Here's a couple clips from today of my FTECU blipper in action: That is pretty badass. Ok Will you may have sold me on it. Guess I need to go test ride a bike with it. What camera are you using? It's a Hero 8 Black with a Ride Tech chin mount (3D printed in ABS), a J-hook mount and a foam wind noise damper, both from Amazon.
Post by mt10orc on Jun 25, 2022 7:56:20 GMT -7
That is pretty badass. Ok Will you may have sold me on it. Guess I need to go test ride a bike with it. What camera are you using? It's a Hero 8 Black with a Ride Tech chin mount (3D printed in ABS), a J-hook mount and a foam wind noise damper, both from Amazon. Thanks man. The rubber duck and pinwheel is f’n awesome. Just noticed it.
Post by willl84 on Jun 27, 2022 9:13:44 GMT -7
It's a Hero 8 Black with a Ride Tech chin mount (3D printed in ABS), a J-hook mount and a foam wind noise damper, both from Amazon. Thanks man. The rubber duck and pinwheel is f’n awesome. Just noticed it. I've seen those in other rider's videos and had to have one lol. It does squeak and it also lights up for night time riding. www.amazon.com/wonuu-Ornaments-Dashboard-Decorations-Propeller/dp/B08BYJGHNQ
amateur
Post by amateur on Jul 1, 2022 18:33:39 GMT -7
I don’t think it would be a straight forward plug and play retrofit. The ‘22 have the 6 axis IMU and TFT dash, to me that indicates a very different wiring loom. My ‘17 MT10 came with the “up” quick shifter fitted from the factory. I wasn’t a fan of any quick shifter on road bikes until I got my MT10 a few years back. I like the factory fitted version. I’ve got a ‘10 R1 with an aftermarket “up” quick shifter fitted and it’s crude compared to the factory job. My new MT10SP gets delivered in a week, that’ll be my first experience with “up & down” quick shifter I’ll have experienced. Happy happy, joy joy!
amateur
Post by amateur on Jul 9, 2022 19:39:10 GMT -7
I’m pleased to report the delivery of my ‘22 MT10SP 2 days ago. It’s winter here in New Zealand, fortunately that just means it’s a little cold and decidedly wet for a couple of months. I was fortunate to find reasonably dry roads out there this morning so I got to ride it for about 200klm. It is noticeably smoother than my ‘17 in the fueling and “quick shifter up” action. Very impressed with the Ohlins active suspension, noticeable changes in compliance between the modes. I was intimidated by the vast range of set able electronic options initially but it’s no more complex than an iPhone once you get familiar with it. It will be a very interesting comparison next time I ride my ‘17 MT10.
Post by mt10orc on Jul 10, 2022 5:11:53 GMT -7
I’m pleased to report the delivery of my ‘22 MT10SP 2 days ago. It’s winter here in New Zealand, fortunately that just means it’s a little cold and decidedly wet for a couple of months. I was fortunate to find reasonably dry roads out there this morning so I got to ride it for about 200klm. It is noticeably smoother than my ‘17 in the fueling and “quick shifter up” action. Very impressed with the Ohlins active suspension, noticeable changes in compliance between the modes. I was intimidated by the vast range of set able electronic options initially but it’s no more complex than an iPhone once you get familiar with it. It will be a very interesting comparison next time I ride my ‘17 MT10. That does look nice. I think I could get used to the different look of the front. Looks a bit more naked than previous gen, the mirrors stick out more so than before. like the new master cylinder, So two MT’s does your partner ride as well?
