stealth
Post by stealth on Feb 2, 2022 17:47:29 GMT -7
Hello,
I got new Translogic auto-blipper for my MT-10. I'd like to ask if anyone can suggest and attach pictures how to install auto-blipper and make it works without activating breaks (yes it is possible to do so). I contacted Translogic and this is what they said:
"The black wire that exits from the ECU to the 3 way connector is the Blip enable wire,
this is connected to the rear brake light, it gets 12V when the brakes are activated,
hence allowing the Blip Assist to blip only when braking.
If you would prefer the bike to blip at all times, not just when braking,
this black wire from the ECU should be connected to an ignition live, therefore
enabling the blip at all times.
You could tap into the feed for the rear side light, this is always on when the ignition
is on."
Can anyone help me to understand how can I do that please? I'd be super grateful to you!
Thank you in advance!
Post by willl84 on Feb 3, 2022 7:58:14 GMT -7
